Had an oil leak under the hpop..so I removed the Hpop and found that the bolt under the pressure lines was loose...........so I got my wrench and tightened down a bit on it and it kinda gave way as in "partially stripped" . Now..I tightened up as as much as I could and reinstalled it, tried to crank engine with no success. So I got out and underneath my truck was flooded with oil. I looked at my Hpop and noticed the stripped bolt was missing from my pump!! It blew out!! Any of you guys have a suggestion on whether this can be fixed or not. Also what is this bolt for? It has probably only 6-8 threads on the shaft and followed by a needle type pin. Any ideas? Thanks...Corey
over 30 views and no help.......Oh well guess I'm off to find a pump!
Ok went to a salvage yard and found a used pump with an ipr valve still attached, put new orings in it and everything seems to be fine so far (knock on wood ) Starting to get real acqauinted with these PSD's
