Sponsored by: Auxito
PCM??
Old Jan 12, 2010 | 10:23 AM
GSDFX4's Avatar
GSDFX4
PCM??
Hey everyone, noob here so be gentle. I recently became the owner of a 2002 f150. It has the 5.4 in it and has been doing great till recently. When i got the truck the speedo and cruise control were not working and the overdrive light flashes. I took it to 2 different dealerships one said the pcm was bad and the other said there was a sensor in the transmission that went out that needed to be replaced. I have ruled out the transmission sensor because i just put a new transmission in the truck. So, before i go and spend more money does this sound right? Also, they replaced a few other things like the speed sensor and display thing for all the gauges. Thanks for you time and help.
Old Jan 12, 2010 | 12:58 PM
galaxie641's Avatar
galaxie641
We need to know the actual code number it is throwing. The OD light flashing is the CEL for the tranny, if the truck is driving fine I'd guess a sensor is not plugged in/bad or a harness is unplugged/cut. Most like the VSS, even though you say it was replaced.
Old Jan 12, 2010 | 04:53 PM
GSDFX4's Avatar
GSDFX4
The truck does run fine but every now and then it wants to shift kinda ruff or hesitate to go into gear from a stop. It will rev up then go into gear every now an then. The 2 codes are P0430 and P0420.
Old Jan 12, 2010 | 06:15 PM
projectSHO89's Avatar
projectSHO89
Those are cat efficiency codes and are not going to tell you anything about the operational symptoms.
Since you just put a transmission in, take it back. Ruling out a transmission sensor because the transmission was just replaced is an exercise in unreasonable optimism. You have a flashing O/D light and you'll need a better scan tool to pull transmission fault codes.
Old Jan 12, 2010 | 08:11 PM
fordtech08's Avatar
fordtech08
check your wiring coming from the trans up to the pcm I bet they are chaffed the wires for the o2 sensors are in the same harness
Old Jan 13, 2010 | 06:33 PM
JJ98's Avatar
JJ98
well ive had the same thing go wrong in my 98 f150 changed tranny after i got it then a few month later it didnt wont to go after work plunged in my scanner and it said tranny power vale so i order a new one on warrnty dindt fix it it was my pcu the power train took a dump oreder a new one from autozone for 180 thats with core fixed and ruuning better than when i got it
DPDISXR4Ti
Mar 21, 2013 01:33 PM
madmarge24
1997 - 2003 F150
Jan 31, 2013 11:14 PM
rknight29
20
Jan 16, 2011 08:24 AM
Jackemupjoe
Jan 14, 2011 11:48 AM
NX Brad
Dec 30, 2005 06:08 PM
