Sponsored by: Auxito
please help
Old Jan 28, 2013 | 05:23 PM
madmarge24's Avatar
madmarge24
please help
I have a 2004 ford f150heritage.transmission blew rear seal lost all fluid.noticed drive shaft was bent and wore the shaft hole.changed transmission with used transmission.Truck shifted then digital mileage stoped woking and ligt on lever forod started flashing.drove home checked fuses.changed one in the panel that was blown.drove truck mileage worked and od light quit flashing but it wont shift from first gear.diagnostic said shift sensor.changed that and no difference.can manually shift from first to second.transmission has warranty so i returned it for another.changed transmission again.still does same thing.ford told me that the pcm is the only other thing that controls that controls the shift of the transmission.changed brain brand new.took to ford had it keyed for new brain.still the same thing and changed sensor on rearend cause speedometer says ten miles an hour no matter how fast u go.please help am running out of money and this is my only transportation.what do i do
Old Jan 29, 2013 | 07:21 AM
fabmandelux's Avatar
fabmandelux
Moved to proper forum.
Old Jan 29, 2013 | 07:43 AM
MCDavis's Avatar
MCDavis
Actually, the 04 Heritage belongs down in the 97-03 F150 forum. It's essentially a 2003 carryover.
Old Jan 31, 2013 | 07:46 PM
Stewart_H's Avatar
Stewart_H
Been sick for two days so I didn't see this until now.
Moved to the '97 - '03 F150 forum.
Stewart
Old Jan 31, 2013 | 11:14 PM
Bluegrass 7's Avatar
Bluegrass 7
Respectfully, your post is very hard to read and get the info needed to begin to help.
Very first thing is are there any codes set, especially in the 700 range indicating the transmission has electrical problems?
Are there any engine codes?
We need a place to begin considereing the causes of your problem.
Good luck.
RSchoe
1997 - 2003 F150
Mar 23, 2015 05:33 PM
madmarge24
2004 - 2008 F150
Jan 31, 2013 08:03 PM
lilreddevilF-100
99
Jul 18, 2011 06:12 PM
