Hey guys, I've been searching for instructions on how to install cv halfshaft or removal of it and have found nothing. I've got a cut in boot next to driver side actuator figured I'd replace it now before further damage occurs. Does anybody have any insight on this? What to take loose etc... Thanks for any input.
Go buy or borrow a Haynes or Chilton manual.
Read the applicable section.
Disconnect the shaft from the diff.
Remove the nut from the end of the shaft.
Remove the shaft from the hub.
You may need to drop the lower "A" arm to get the shaft out of the hub.
Install is the reverse.
