Changing the front seal...
Old Jan 11, 2010 | 04:11 PM
Shade's Avatar
Shade
I just found a small leak today coming from behind my harmonic balancer, I'm assuming it's the front main seal? I ordered the seal today but was wondering if there's anything unexpected I should know before I start pulling the front components off this weekend. i.e. can I just pull the balancer off, change seals, then replace the balancer or is it more complicated like dropping the oil pan or loosening the main cap bolts to loosen the front of the crank? Hope it's not a dumb question I've just never seen the front of a Powerstroke stripped before so I don't know exactly how it's put together. Thanks for any info ya'll have for me.
Old Jan 11, 2010 | 08:51 PM
ChunderDownUnder's Avatar
ChunderDownUnder
There's a couple of recent threads regarding this that might help ya
https://www.ford-trucks.com/forums/9...al-2002-a.html
https://www.ford-trucks.com/forums/9...-oil-leak.html
Old Jan 12, 2010 | 02:38 PM
Shade's Avatar
Shade
Thanks for the links Chunder, good info in there. I guess I didn't use the right terms in 'search'.
Old Jan 12, 2010 | 02:58 PM
clux's Avatar
clux
I replaced mine a few years ago, I think I had to pull the fan and shroud off to get the balancer off, and then it took some redneck engineering to press the seal in. But I think you can just remove the oil pump and press the seal in it off the engine.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 26, 2023 11:24 PM
zwaechte
Sep 21, 2015 11:52 AM
rangerrick63
15
Jan 9, 2010 08:24 PM
rangerrick63
Jan 8, 2010 06:29 PM
funzjb1
Jan 6, 2010 07:02 AM
