Used trany problem
Old Jan 9, 2000 | 12:27 PM
Brady's Avatar
Brady
Used trany problem
Need info. I just put a c6 out of a 1988 f-150, in my 1965 truck, I changed the front and rear seal,filter, and vacuum modulater.The trany wont shift into drive or any other forward gear untill it get warm. It takes about 15 minutes. I checked all the regular, fluid level, shiftlinkage, and it is all good. I shifts to reverse no problem. Any suggestions would help. I think it is probley hard seal...
Old Jan 9, 2000 | 04:49 PM
Bill at Hardcore 4x4
Guest
Posts: n/a
Used trany problem
When you replaced the modulator valve did you reinstall the small pin in the center? This keeps the valve in place in the trans case.Without it the valve will go to the end of its travel as soon as there is pressure and bleed off the hydraulic pressure to the forward gears.If this isnt the problem the forward clutches are probably toasted . These are applied in all the forward gears and if they are burned up it wont work very well in forward.
Old Jan 9, 2000 | 05:22 PM
StockMan's Avatar
StockMan
Used trany problem
Badboywrench
Jan 9, 2012 07:34 PM
Glockem45
20
Jun 29, 2009 07:17 PM
Boonebird
Apr 28, 2008 11:12 AM
reifwj
Apr 13, 2008 08:58 PM
crash104936221
1983 - 2012 Ranger & B-Series
Nov 7, 2002 05:10 PM
