Cold Start Video Thread
Old Jan 11, 2010 | 07:51 PM
c00nhunterjoe's Avatar
c00nhunterjoe
hang on now, what are the criteria for glow plug ontime in this new challenge?
Old Jan 11, 2010 | 08:59 PM
Talyn's Avatar
Talyn
I always cycle mine 2 times before I start in real cold, otherwise it sounds like its going to tear itself appart when it fires.
Old Jan 11, 2010 | 09:18 PM
c00nhunterjoe
well see now these are things we all need to be on the same page about when making a cold start video thread!
Old Jan 11, 2010 | 11:31 PM
strokin'_tatsch's Avatar
strokin'_tatsch
screw it, fire it off as soon as the light goes off. i will do it if you and william will do it. haha
Old Jan 12, 2010 | 12:34 AM
444dieselrod's Avatar
444dieselrod
Ditto to that, its the only way to take out the variables. I normaly wait 5 seconds or so after the light goes off.
Lets go for a coldest start NO block heater. I started mine the other day it was -14ºF and it wasn't plugged in. I already plugged mine in for tomorrow morning so its to late, and Wednesday it might get above freezing here so that defeats the purpose because its not cold unless its below freezing.
Diesel Rod
Old Jan 12, 2010 | 04:44 AM
Talyn's Avatar
Talyn
Diesel Rod
Yea. in all honesty, when the light goes off, turn the key.
For test purposes.
I'm sure mine will start, but I just like to cycle 2 times, less cranking involved.
And travis, your in texas. You dont count. haha.
And yea. of course no block heater, its not a cold start with that. =)
Old Jan 12, 2010 | 10:18 AM
MADVAN's Avatar
MADVAN
This was not meant to be a challenge on who has the best cold start.
If you doctor your start, what gains in info have you learned about your truck.
My thoughts were more about the condition of your motor, injection, oil, tune, mod combos ect. There are many variables on how well they start. I have seen how even a pump change effects cold starts. Example--If you have a 17* pump you have a slight advantage over the 15* pump. A modded 17* will have a disadvantage over the 15 and 17.
Agree on the WTS lamp off then hit it.
Its how joe public would start it.
Bill
Old Jan 12, 2010 | 12:56 PM
triskadek's Avatar
triskadek
I'll be in as soon as it is cold again...at -11 C (+11 F) it isn't impressively cold.
Old Jan 12, 2010 | 07:56 PM
2 stroke man's Avatar
2 stroke man
ok guys, sorry it is so dark...5:30am as i was headed to the gym. she started good imo. 22 degrees after soaking from Saturday to Tuesday morning, windchill around 12. Below freezing the whole time during soak. I started it immediately after the first GP cycle. I started it up, then tailpipe view, then back to cab for High Idle, and EBPV switch flip. Then a look out front to show no plug (it was too dark to see). Anyway, let me know what you think.
Old Jan 12, 2010 | 08:55 PM
c00nhunterjoe
not a bad start in my opinion, i cant play till i pick up a new relay, mine finally went bad, lol, i have been jumping it with a wire the last 2 days
Old Jan 13, 2010 | 06:45 AM
MADVAN's Avatar
MADVAN
Looks good here 2stroke.(sound)
You have a tw tune. What weight oil and
fuel additives if any?
Bill
Old Jan 13, 2010 | 09:43 PM
2 stroke man
Bill
Definitely TW FTW!
Shell Rotelly 15-40 with NO ADDITIVES...Used to run lucas and it started like crap last winter till i stopped the Lucas.
I do not believe the fuel had any additives, but i think something did maybe turn it RED???? mwahhahaha
Old Jan 14, 2010 | 07:41 AM
  #28
MADVAN's Avatar
MADVAN
Be carefull with the tomato juice.
Bill
Old Jan 14, 2010 | 12:06 PM
  #29
Talyn's Avatar
Talyn
Lucas foams up the oil. =(
Get a stancore Joe. Just go for it, cheep and worth every penny!
Old Jan 14, 2010 | 02:52 PM
  #30
foxracing0934's Avatar
foxracing0934
Ya mine used to start like your 2 stroke, but the past few times its been real cold she hasn't wanted to fire. I've had to cycle the plugs 2-3 times and she smokes white bad until it finally fires, probably something to do with the II's throwin more fuel at it but idk. I'll have to see if I can get up early enough next time its cold enough to play, but the way its going I could probably start it when its 30 degrees and you wouldnt know the difference. Gonna have to figure out what this problem is.
