Overheating
Old Jan 12, 2010 | 12:21 AM
starmilt's Avatar
starmilt
How hot is it getting and do you have a mechanical guage. My fan clutch doesn't come own until 205 usually on a hard pull and never stays on maybe a minute it shuts off about 200 degrees.
Are you ever spitting water out.
Old Jan 12, 2010 | 02:24 AM
Dave Sponaugle's Avatar
Dave Sponaugle
If you are at 2000+ RPM, there is no mistaking when the fan clutch locks up, loud exhaust or not.
Old Jan 13, 2010 | 08:53 PM
Dirtboy953b's Avatar
Dirtboy953b
Does antone know the part # for a IH therostat?,the IH dealer said they need the engine ser# and I can not find it I looked on the pass side valve cove and it was not there
Old Jan 13, 2010 | 09:10 PM
87crewdually's Avatar
87crewdually
The serial # is on top of engine on the flat area to the right facing side of the injection pump cover, sort of below/behind the a/c compressor. It's probably dirty so you'll have to really clean and search for it. Maybe someone will come up with that # for you.
Old Jan 13, 2010 | 09:38 PM
9473's Avatar
9473
Motorcraft # E5TZ-8575-C They can convert to Int#
Old Jan 13, 2010 | 09:40 PM
wreckinball's Avatar
wreckinball
i know someone has a better picture but this will help. Look at the ip housing right side bolt as you are looking at it, it is on the block right behind it. The first number which would be a 7 as in 7.3 is usually hidden under a bead of silicone.
Old Jan 13, 2010 | 09:51 PM
9473's Avatar
9473
Originally Posted by wreckinball
And the juice can is over on the left side.
Old Jan 13, 2010 | 10:56 PM
Dirtboy953b
Old Jan 13, 2010 | 10:59 PM
starmilt's Avatar
starmilt
X2??????????
Old Jan 13, 2010 | 11:01 PM
87crewdually
It seems to me he mis-posted some how?
Old Jan 13, 2010 | 11:07 PM
mechelement's Avatar
mechelement
I picked up my Ford thermostat today and asked what temperature it opens up. The guy told me 192 degrees.
Old Jan 13, 2010 | 11:12 PM
wreckinball
the juice can is from me in another post probably. I have the black plastic round container for vacuum storage not the juice tin so when i heard them chatting it up in another thread i promtly said WTF?? haha. sorry for the confusion. find the block serial yet?
Old Jan 14, 2010 | 12:04 AM
  #28
starmilt's Avatar
starmilt
The thermostat has the opening number stamped on it.
Old Jan 14, 2010 | 11:18 AM
  #29
Dave Sponaugle
That canister on the left side of that picture is the AC drier.
Old Jan 14, 2010 | 12:30 PM
  #30
wreckinball
way off topic but is the black plastic ball i have, my vacuum storage? i believe so!
