Coolant filter change?
Old Jan 10, 2010 | 08:04 PM
mhays2's Avatar
mhays2
I added my coolant filter today (pics below). I have come to appreciate and depend on this forum for sage advice. Thanks...
I have searched but couldn't find a filter change interval. How often do you change yours?
www.ford-trucks.com/forums/album.php?albumid=6167&pictureid=23593
www.ford-trucks.com/forums/album.php?albumid=6167&pictureid=23592
Old Jan 10, 2010 | 08:09 PM
mhays2's Avatar
mhays2
And, no... after looking at my post (pictures) - I do not work for Amsoil.
Old Jan 10, 2010 | 08:17 PM
03-6L-X's Avatar
03-6L-X
Go to DieselSite's site. They have suggested change intervals posted.
Old Jan 10, 2010 | 08:21 PM
BigRy's Avatar
BigRy
I think it is change for first thousand miles three times and then every 10K miles thereafter. I could be wrong, but I think it is on Dieselsite.com
Also, I got to ask? How do you like the bypass filter kit? Is that the same one from Ebay?
Old Jan 10, 2010 | 08:28 PM
mhays2's Avatar
mhays2
I like the by-pass systerm a lot and the kit was great (complete and easy). I ordered it directly from Amsoil.
Go here; POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners for good instal instructions
Old Jan 10, 2010 | 09:38 PM
04scurs's Avatar
04scurs
Nice job! Exactly like mine. lol Went to the same site and got the idea for the oil bypass and then did just like you did for the coolant bp. Mine has been in about three months now. Just had an oil analysis done and it came back great after about 5,500 miles. The coolant hose after the filter is still hot, while running, so I guess it is not to clogged up yet. However it is on the list of things to change. I did have to lower my filter mts. down on the angle iron piece so they would clear the hood liner though. I see you also wired up your winch the same way too, it is the easiest way though. The Dieselite site has the change schedule. Good pic's too. I didn't take any as I was in a hurry so yours will make a good set to look at for others.
Old Jan 11, 2010 | 05:11 AM
dschuffert's Avatar
dschuffert
Great looking setup. I just watch the flow. I am tinkering with the truck almost every weekend anyway. So every weekend I simply open the degauss bottle cap, looking in from an angle, check to see that a healthy flow is still going. I change either annually or one the flow slows down.
Old Jan 11, 2010 | 06:25 AM
CombatMedicF-250's Avatar
CombatMedicF-250
I'm very impressed with the set-up! Gives me a few ideas for sure!
Great Job!
Old Jan 11, 2010 | 06:51 AM
Cowboy65's Avatar
Cowboy65
Follows is DieselSite's recommended filter change intervals:
Recommendations on filter changes:
Use one filter every three months for the first nine months after installation. The lack of flow into the expansion tank is an indication that your filter is plugged. Change the filter if it should plug before the 3-month interval. After the 4th filter is installed your filter should be changed once per year.
Old Jan 11, 2010 | 09:36 AM
lawnboy1965's Avatar
lawnboy1965
When i put mine on it was suggested to change at 500 miles (waste on mine, others I know of were plugged though), 1000 miles, 6 mos, then once a year.
pilot31
41
Sep 2, 2017 09:23 PM
Kazoo
Nov 15, 2012 11:58 PM
84-6.9L
Mar 28, 2011 08:03 AM
Deluxe06
13
Jul 27, 2010 09:30 PM
1996pwrstrk
Feb 28, 2010 03:33 PM
