Need help with a misfire problem.
Old Jan 10, 2010 | 09:33 AM
Double-T's Avatar
Double-T
The otherday I was driving my truck, 1989 Ford F-450, then out of nowhere it just started missing like crazy. Looked behind me and it was white smoking like crazy.... I was thinking an injector was bad.... Get out today and check the injectors (cracking the fuel lines while its running) and find the on I thought was bad.... Had some good USED ones laying around so I put one in it but still missing. Cracked the line. No change. Tried another injector same thing....... ANY IDEAS?
Old Jan 10, 2010 | 09:37 AM
wreckinball's Avatar
wreckinball
just curious but what did the smoke smell like? Does it still do it? Is it a constant smoke or sporadic?
Old Jan 10, 2010 | 09:52 AM
Double-T's Avatar
Double-T
It smells like a fuel smoke.... It does it all the time and idles really rough... The thing starts up fine but idles rough as a cob and misses and smokes really bad when you drive it
Old Jan 10, 2010 | 09:56 AM
starmilt's Avatar
starmilt
If you are certain the inj was good check your valve train. compression test.
Old Jan 10, 2010 | 09:58 AM
wreckinball
sounds like the IP but how is the timing, how old is it, how old are the injectors and did you change anything in the past week like additives or fuel?
You may want to get a bottle of diesel kleen and remove the fuel filter, empty the diesel out into a clear container. Fill the filter with the diesel kleen then reinstall, start the truck and let it run for about 15-20 seconds, then shut it off. Let it sit for about two hours and then take it out for a run. It has cured more problems than i can list. Try that first but let us know about the other stuff above as well.
Old Jan 10, 2010 | 04:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Double-T,
Welcome to FTE and the IDI forum.
Sounds like an injector not popping closed to me.
Do you notice the offending injector is hotter than the others?
Old Jan 11, 2010 | 05:52 AM
Double-T's Avatar
Double-T
I didnt notice ifi ti was or not....
Old Jan 11, 2010 | 07:50 AM
PLC7.3's Avatar
PLC7.3
Good possibility it is either a bad injector or a valve not closing due to worn guide. I would say the suggestion to check valve train operation is pertinent.
If you remove the valve rocker... push the valve(s) one at a time down 1/4 inch and try to wiggle them...... any significant movement is a warning guides are worn. If the wear is too bad the valve can stay open and operate like the one in the info below.
TheDieselStop.Com - www.thedieselstop.com
Old Jan 11, 2010 | 06:55 PM
rupejosh's Avatar
rupejosh
let the motor run for about 5-10 minutes and then shut it down and feel the injector lines at the injector and see if any are hotter then the others,if you find one that is you have found the culprit injector.i just went through this with mine and let me tell you it was obvious
Old Jan 15, 2010 | 09:34 PM
Double-T's Avatar
Double-T
Well today after I pulled tha valve cover I discovered my problem... A bolt had backed out of the rocker arm on a intake valve and it wasnt letting the pushrod contact the rocker to open the valve. I tightened it back down, buttoned it all up and it runs like a top......
Thanks guys for all the input,
Double-T
Old Jan 15, 2010 | 10:24 PM
dyoung14's Avatar
dyoung14
Double-T
yep thats exactly what i thought it was till i read down and you already found the problem, i know on injector not seating is not enough to make that one run that bad and smoke that bad, cause i got atleast on injector hung open right now and it has a slight miss and is dumping fuel in the engine i have a slight trail of blue smoke all the time now, and it burns my eyes and throat when i breathe it, so im going to pull the injectors send them to the injector guy and get him to fix them and re set my pop pressure to around 2300 instead of 1850
Old Jan 15, 2010 | 10:26 PM
rupejosh's Avatar
rupejosh
wont setting the pop pressure that high make your ip go bye bye?
Old Jan 15, 2010 | 11:48 PM
dyoung14's Avatar
dyoung14
why? turbo motors the injectors were close to 2200, plus my ip is a rebuild,
tje2015
15
Mar 12, 2012 04:55 PM
boots6868
Sep 2, 2011 09:17 PM
lmnr0026
17
May 20, 2009 11:53 PM
TurtleRacing
19
Dec 27, 2007 11:42 AM
fordf350crazy
Jul 27, 2005 05:37 PM
