Looking for a pulley...(?)
Old Jan 10, 2010 | 03:48 AM
monkei's Avatar
monkei
Question Looking for a pulley...(?)
I'm trying to find someone who makes a crank pulley in aluminum that isn't underdrive for a 95 351w/Bronco application. Does anyone know a manufacturer / part number. Tried looking in the net but couldn't find anything.
Old Jan 10, 2010 | 04:40 AM
lew52's Avatar
lew52
Try March performance pulleys , they should have something....Lew
Old Jan 10, 2010 | 09:11 PM
Boba Fett's Avatar
Boba Fett
NAPA might have a stock replacement for the app.... underdrive/overdrive is more a function of the ratios between the pulleys..... if not march is also a god option.... or you might have to look for one in a junkyard....
Old Jan 10, 2010 | 10:32 PM
monkei's Avatar
monkei
I'll call March and see if they'll sell me just a crank pulley, I thought they were in the business of selling only the high dollar kits.
I'm looking for an aluminum pulley if possible.
Old Jan 11, 2010 | 06:32 AM
Boba Fett's Avatar
Boba Fett
then march is your best option..... their tech support is great... they have helped me with my projects in the past....
Old Jan 13, 2010 | 01:45 PM
monkei's Avatar
monkei
Nope...damn
"Patrick,
We do not sell a stock replacement pulley for that application. I would probable check Ford Racing at 1-800-ford-788.
Thank You,
Elijah"
Old Jan 13, 2010 | 01:53 PM
lew52's Avatar
lew52
Why do you need an aluminum pulley ??? I use the underdrive pulleys & they work great .....Lew
Old Jan 13, 2010 | 02:00 PM
monkei's Avatar
monkei
I dunno, why do I need a supercharger
I need to replace the stock crank pulley, it's all screwed up. I would prefer aluminum, that's all really.
Are you using the power&amp kit?
Old Jan 13, 2010 | 02:15 PM
lew52's Avatar
lew52
Ok , cool , superchrger !!!! Whats the power & amp kit ??
Old Jan 14, 2010 | 03:02 PM
monkei's Avatar
monkei
March Performance Power & Amp Series Pulley Kit 79-93 5.0l Mustang & F Series Truck 1015
"Great for vehicles with automatic transmissions or high amperage needs. Excellent for heavy stop and go driving. Includes the following pulleys 4 3/8" Ribbed Crank Pulley 5 1/2" Non-Ribbed Water Pump Pulley 1 11/16" Ribbed Alternator Pulley Application: 1979-1993 Mustang 5.0L 1986-1996 F-150 5.0L 1987-1996 F-150 5.8L 1985-1988 Thunderbird 5.0L 1991-1992 Thunderbird 5.0L 1985-1992 Lincoln Mark VII 5.0L"
http://broncograveyard.com/bronco/i-...billet_kit.htm
^That one's aluminum
"Power & Amp Series:
Increases horsepower by reducing accessory drag. 11 h.p. at rear wheel.
Design for vehicle with automatic transmission or high amperage need.
EXCELLENT for heavy stop and go driving, off-roading, and or towing.
These aluminum sets are machined from 6061-T6 billet aluminum for extra strength.
Hand polished and covered with a “No Polishing” clear powdercoat. and a durable hard coating on the crank pulley that prevents oil seal leak"
Old Jan 14, 2010 | 03:27 PM
lew52's Avatar
lew52
I used the trickflow pulleys , crank , waterpump , alt ....For the 5.0 mustang..Never had any problem with the alt not charging the battary...Lew
Old Jan 14, 2010 | 04:08 PM
monkei's Avatar
monkei
What size is the crank pulley?
Old Jan 15, 2010 | 05:12 AM
lew52's Avatar
lew52
I don't know , don't see the size anywhere ??
Old Jan 15, 2010 | 06:43 AM
Sand_Man's Avatar
Sand_Man
Just a little FYI, but if you really want one and cannot find one, consider having one made at a machine shop. I'm a machinist and have made them for a local hot rod shop and it really doesn't take much time at all. Now that aluminum stock is once again affordable it won't cost too much at all if you find the right shop.
Old Jan 15, 2010 | 11:42 AM
monkei's Avatar
monkei
Yeah, I've considered it, as another machinist/toolmaker. I work in a CNC shop and could model the pulley in Solidworks or CAD but I'm not allowed to make my own parts on our lathe or mill turn center.
What'd the custom pulley you made end up costing?
