69 f100 steering column
Old Jan 9, 2010 | 11:54 PM
69-f100's Avatar
69-f100
i was wondering what steering column would be best for a 1969 f100. its a 4 on the floor. and all it needs is the turn signals on the column. thanks
Old Jan 10, 2010 | 04:41 AM
jowilker's Avatar
jowilker
Any 65-72 will replace, 73-79 with Ford power steering. I run a 76 column in my 66.
John
Old Jan 10, 2010 | 08:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Why do you need to change the column, are you adding P/S?
If so, there are two different length P/S columns used in 1969, because there were two different P/S systems: Bendix & Ford.
If you using Bendix P/S, you will need a 1967/69 column used specifically with Bendix P/S.
If you are installing Ford P/S, see jowilkers post above.
btw: If this is a 4WD, the entire equation changes.
Old Jan 10, 2010 | 06:30 PM
69-f100's Avatar
69-f100
i am replacing it because the bearings dropped out of it.
also its not power steering.
are there any kits to get new bearings or should i just get a new column
Old Jan 11, 2010 | 04:22 AM
jowilker's Avatar
jowilker
Contact Rick @ Carolina Classics 800-598-4211
They rebuild them & can advise.
John
Old Jan 11, 2010 | 05:54 AM
NumberDummy
i am replacing it because the bearings dropped out of it, also its not power steering.
Are there any kits to get new bearings or should i just get a new column
There are two bearings used in the steering column. One is hand pressed into the upper flange, a plastic ring keeps it in place.
One is at the bottom of the steering column pressed by hand into a retainer.
The upper bearing cannot fall out, the lower bearing's retainer could have cracked apart, allowing pieces of it to fall out.
The upper & lower bearings are the same: C3DZ3517A and are still available from Ford (@ $3.97 each) as they fit myriad car/truck applications from 1957 thru 1979.
The lower bearing retainer is obsolete, but can be found at Ford Dealers & obsolete parts vendors:
C5TZ3D681A .. Lower Steering Column Bearing Retainer Assy.
Fits: 1965/66 F100/250 2WD w/Manual Steering // 1967/72 F100/350 w/ Manual Steering / 1969/72 F100/350 2WD w/ P/S / 1973/79 F100/350 2WD w/ or w/o P/S.
MATLOCK FORD-MERCURY in Franklin IN has TWO = 800-987-3673.
GRIESEL MOTOR CO. in Okarche OK has TWO = 405-263-7242.
MILLER OBSOLETE PARTS in Binghamton NY has THREE = 800-546-7278.
TISON MOTOR CO. in Estill SC has FOUR = 803-625-2551.
DON SANDERSON FORD in Glendale AZ has TEN = 623-842-8762.
Old Sep 16, 2010 | 09:34 PM
Krispy's Avatar
Krispy
Jowilker, do I understand correctly, any 65-79 with power steering will work? I'm trying to put an automatic column in a '67 with power steering. Didn't know until reading this thread what the difference was between a Bendix and Ford. I'll look at the P/S to see if there's a marking on the gearbox. Thanks and hope to hear back.
Old Sep 17, 2010 | 03:29 AM
jowilker's Avatar
jowilker
No, The column length is different. The Bendix gear column is closer to the length of non-power. The Ford gear has hydraulic lines on top of the gear making the column about 2 1/2" shorter.
Bill can offer correct, but I believe the Bendix gear has 4 bolts on top while the Ford had 2.
John
Old Sep 17, 2010 | 07:57 AM
Krispy's Avatar
Krispy
F100 Steering Column
Thanks for the info. Man, you're up early. Take care and make it a great day.
Catanna69
Ford Truck Parts for Sale
Dec 2, 2016 05:56 AM
69Flareside
Jun 20, 2016 08:55 PM
dbyrd342
May 24, 2016 01:37 PM
BuickBrian
Jan 3, 2013 03:49 PM
Victor L
Jul 7, 2010 07:44 PM
