Sponsored by: Real Truck
Back up sensor
Old Jan 8, 2010 | 01:34 PM
Johnny Bravo 45's Avatar
Johnny Bravo 45
Back up sensor
I just purchased my Ford F 250 superduty 2002 with a 5.4 triton V8.
My back up sensor system worked for one day. Today, I noticed the light that indicated the back off sensing system is off ...was illuminated indicating the system was off. I tried to turn in on and it would not turn on??? When I start my truck, I hear a small churp. When the truck is in drive, I can turn the system on, but as soon as I put my truck in reverse, the light illuminates and indicats the system is off.
What gives?
I checked the fuses under the dash and all are good.
I purchased a Haynes repair manual, and they are pretty much useless on these issues.
Any help would be greatly appriciated!
Old Jan 8, 2010 | 06:37 PM
Fordfanatic4life's Avatar
Fordfanatic4life
disconnect the sensors, at the rear bumper, clean the connectors and try it again...
Old Jan 9, 2010 | 10:14 AM
Johnny Bravo 45
I tired cleaning the sensors with brake cleaner, plugged them back in and it still does not work
Old Jan 9, 2010 | 10:49 AM
Johnny Bravo 45
OK,...,...,..,.,
I went out to my truck this morning, the back up switch was acting kind of funky.....
And after cleaning the terminals last night.....it works ...... for now?
Old Jan 9, 2010 | 10:57 AM
powerstroke72's Avatar
powerstroke72
Could be a bad sensor. Get a good sensor and you can test them by replacing one at a time with the new sensor.
Old Jan 9, 2010 | 10:59 AM
Johnny Bravo 45
I called to price the sensors and they said it was 132.00 per sensor! If that's the case, I'll just spend 100 bucks on a back up camera
Old Jan 9, 2010 | 11:08 AM
powerstroke72
Wow. Well, you could probably pick up a used working sensor at a salvage yard cheaper or if you can find a buddy with the same setup, borrow one of theirs just to test.
Old Jan 9, 2010 | 11:12 AM
Johnny Bravo 45
OK, Now it does not work????
I"m going to go get some electrical contact cleaner and try cleaning it again. After I hit it with electrical contact cleaner, i'm going to clean the connections with compressed air.
Old Jan 9, 2010 | 11:21 AM
strokingbeast's Avatar
strokingbeast
is there no other way to test these things out. I have had the same issue since i bought my truck two weeks ago. Will sensors from any superduty/excursion work.
Old Jan 9, 2010 | 11:41 AM
powerstroke72
I don't think there have been any changes to the sensors themselves if you're just looking for one to use as a tester. I believe the appearance changed on the '08+ trucks so if you got one from an earlier truck to test with and found a bad sensor you needed to replace, you'd need to get one for that model year if you're concerned with the looks matching and the correct fitment. I believe the sensors in the '08 trucks fit a little differently as the bumper contour changed.
Old Jan 9, 2010 | 12:42 PM
Johnny Bravo 45
Well, from what I've found per price points, I"m just going to install a back up camera for 100 bucks. That's 30 bucks cheaper than ONE sensor!
Old Jan 9, 2010 | 03:08 PM
strokingbeast
yea my brothers 6.0 f250 has been at a ford dealership for a year and a half so i dont think he needs those sensors right now
Old Jan 9, 2010 | 05:07 PM
bayou barataria's Avatar
bayou barataria
A year and a half? sounds like the switch to me.
Old Jan 10, 2010 | 11:00 AM
strokingbeast
well his truck has been there for it leaking antifreeze all over the place, and just a couple of weeks ago they finally figured out it was the head gasket. after two years of the same issue four egr coolers, and whatever goes along with it. O and the truck only has 40,000 miles on it
Old Feb 24, 2010 | 03:40 PM
worm5932's Avatar
worm5932
my 01 does that same thing! when i baught it i made the dealer diagnose the problem and get me the parts.......$500 backup module wasnt it. im leaning to the switch but havent messed with it in over a year.
dmarsh2400
Aug 19, 2019 03:23 PM
guitar4him
Aug 3, 2013 01:58 PM
Ex03AK
Mar 17, 2012 08:38 PM
FreeFall
1997 - 2003 F150
Aug 7, 2011 09:22 PM
