EGR Delete, Fuel Injectors, and Codes
Did the viper installer run a wire to one of the injectors for the signal to let the viper know that the truck is running, or did he use the tach generater relaymajig like texans? I have an elcheapo remote start that works perfect just sensing system voltage. I origanally installed using the injector wire trick (per the advice of a "professional"). shortly thereafter my FICM went bad. Coincidence? maybe. But it did make me nervous at the time.
i agree never hard of a tuner throwing that code . fcim is fairly pricy have you checked harnesses. and also always replace entire bank of injectors. the labor is way to expensive to do this twice ,also what kind of temps are you running is it to hot maybe glows not doing there job just throwing ideas hope somthing pans out for you
sorry grammer not so good ,but from what i understand chafing could be a cause, if you look in tech folder it should be there. try this link it has helped me
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners & Mechanics
Also might want to make sure that when the Viper turns on, the glow plug light on the dash lights then goes out before cranking starts.
Im new and cant seem to figure out hiow to post a new thread. So i will just ask you who seems to no his stuf. I have a new 2010 F250. What can I do for better fuel economy? Im not looking horse power upgrades just fuel economy. Thanks
problems on the road
Hey there FTE!
I recently purchased a used 03 f350 DRW with the 6.0. I am currently on a road trip moving my daughter cross country and have had a couple of puzzling issues.
1- P0272 - and a hesistation/rough acceleration happened mid-trip, then quickly went away once I pulled over and then left again. I just had all injectors replaced 2 weeks before!!! whats the problem? wiring/injector harness ... any advice? It hasn't returned yet, thankfully, so I'm riding this out for now
2- P2138-40 - Throttle pedal - voltage issue? I'm waiting for a new pedal/TPS unit today but feel like the exixting one may not be the issue. I checked all connections under the steering column, and it has been fine while driving around town. could it just be a bad connection? any input other than starting with the pedal and sensor unit?
I'd love to hear back, I'm in the middle of nowhere (Pendelton Oregon) headed to Colorado (home) in the middle of bad weather, any and all advice is appreciated
First.... start a new thread, this is 6 years old and buried. It won't get looked at since is about a remote starting system.
P272 is at bad injector, they can be bad from the box. Was it a Ford injector from Ford? Hope so.
Could be a bad connection, what's common to all three codes?
P0272
Thanks, and this was a ford injector, under warranty ... just seemed odd to have a problem and then have it totally go away like it did, I've gone another 800 miles on this trip and it hasnbt happened again. I'll have my local shop help when I get back. The other codes are unrelated and part of the throttle sensor/wiring I suppose. It also has gone away since I removed the pedal and checked the harnesses inside the cab
I don't think I can start a new thread since I'm new here ...
T
T
