Outside Air Door
Old Jan 7, 2010 | 08:58 PM
Mark T's Avatar
Mark T
Question Outside Air Door
The handle broke off of the door that allows outside air into the cabin of my 1979 F100. I can't find the part at LMC or Mac's. The door is on the driver side, below the dash on the outside wall. It slides in a frame. My truck has an after-market a/c. This is just the outside air vent, it has nothing to do with the heating or a/c. Where can I find a new part or is there anyway to repair this plastic handle?
Old Jan 7, 2010 | 09:39 PM
4x4 Bart's Avatar
4x4 Bart
I would find one in a wrecking yard. To take it off, you have to remove the parking brake assembly. It has two nuts you access under the left front fender well and one bolt at the lower front edge of the dash. Then you have access to the six #3phillips head bolts that hold the sliding vent.
Old Jan 7, 2010 | 09:50 PM
Poison Oil Racing's Avatar
Poison Oil Racing
I had the same problem so I took a wooden dresser drawer **** and screwed it on and it works just fine. Even painted it black so it doesn't stand out
Old Jan 7, 2010 | 09:56 PM
Mark T's Avatar
Mark T
Did you have to remove the door to get the drawer **** on?
Old Jan 7, 2010 | 10:05 PM
Poison Oil Racing
yes you do. A little bit of a pain.
Old Jan 8, 2010 | 05:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The handle was only furnished with the vent assy. It was not available by itself.
D2TZ1002105A .. Vent Assy / Obsolete
Fits: 1972/79 F100/350 // 1972/79 F500/880 // 1972/91 LN600/900 // 1978/79 Bronco.
WABASH FORD TRUCKS in Indianapolis IN has ONE = 317-244-6811.
PEACH STATE FORD TRUCKS in Norcross GA has ONE = 770-449-5300.
CARPENTER NOS OBSOLETE PARTS in Concord NC has ONE = 704-786-8139.
WESLEY OBSOLETE PARTS in Liberty KY has TWO = 606-787-5293.
Old Jan 9, 2010 | 08:45 PM
muladesigns1's Avatar
muladesigns1
With the pressure that is applied to the handle i would think it to be a temporary fix at best.
I would check on ebay or better yet your local wrecking yard.
I see these in working order fairly often in them.
Old Jan 9, 2010 | 11:28 PM
70 Bronco TX's Avatar
70 Bronco TX
Once again Bill, very good info...I learn a lot each time I log into this website and you're a great resource for parts.
jsutton
Jan 28, 2014 08:36 AM
helirich
1978 - 1996 Big Bronco
May 26, 2010 11:54 AM
Supercab
Aug 23, 2003 09:58 AM
beartracks
Aug 8, 2003 02:27 PM
