truck vibrating after lowering
Old Jan 7, 2010 | 07:13 PM
ernietorrado's Avatar
ernietorrado
Hello my Ford enthisiast:
I got this little problem, I went to lower my 1972 f100 today, just the rear with lowering blocks and flipping the axle on top of the leafsprings. after that my truck vibrates between 2nd and 3rd gear. Two things im suspicious of the diferential is not sitting straight like it was originally, now is in an angle pointing down not more than 5 to 8 degrees and the other thing os that the rear now is compressing the shocks complettely so the is no shock absorption can you help me identify the problem? i thought since it has the u joint it would not make a big difference being in a slight angle.
I appreciate your expertise!!
Old Jan 8, 2010 | 07:50 AM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site Ernesto.
I moved your thread down to a forum that can help you out. Be sure to look over the boards and see what all the site can offer.
Old Jan 8, 2010 | 01:36 PM
jsutton's Avatar
jsutton
It's most likely the pinion angle is off so you'll need some shims to correct it. As far as the shocks go you'll need to get some shocks that are for a lowered truck, your stock shocks are simply too long.
Old Jan 8, 2010 | 01:41 PM
mr.auto's Avatar
mr.auto
yep, the pinion angle is off, thats the vibrations, and did u use loc-tite on the u bolt nuts?
dont want those to let loose.
good luck, let see some pics of that beast
welcome to FTE
Old Jan 8, 2010 | 02:08 PM
starmilt's Avatar
starmilt
While I have never lowered a truck when you lift a truck the driveshaft has to be lenghtened, so it would be the other way when lowering do you have enough play in the slip yoke or is the driveshaft shoved up tight. Plus I second the pinion angle.
Old Jan 11, 2010 | 04:56 PM
ernietorrado
all right gentlemen:
yeah!! you got it my pinion angle was off, had to undo a little welding and repositioned the axle to the correct angle and problem solved. now the shocks are shorter an but need to c notch the frame since the axle is hitting against the frame. future plans are to install bags on all four. i will post some pisc soon when the truck is more where i want it to be. i will take it this weekend to the flea market to hace the mexican style lettering which will say chaparrita consentida which translated is spoiled shortie. hell yeah
Old Jan 11, 2010 | 05:09 PM
mr.auto's Avatar
mr.auto
we like to see pics from beginning to end good luck
68dadto3
May 8, 2011 10:21 AM
49willard
15
Feb 4, 2006 10:25 PM
beartracks
23
Apr 4, 2004 12:33 AM
beartracks
Jun 5, 2003 03:05 PM
