i recently rebuilt the 360 engine on my f250 and after a couple of months of perfect runnning i have a very rough idle. ater changing my timing chain (cause i thought my timing chain skipped a tooth) and my distributor. i have a perfect idle at around 800-850 rpms. the downside is when i put a load on and hit the gas i get a backfire from my carb. any ideas as to what the cause is? im going to check my point gap... i checked my fuel and air ration and thats fine as well. could my vaccum advance hose be faulty? or crossed wires? any help would be awsome
after checking my pooints gap it was off so i moved them to .017 which is manufacturs setting. but i still get the backfire from the carb. anybody have an answer?
When you adjust or change your point gap you are also changing the ignition timing. Lazy or retarded timing will cause a backfire through the carb. Temporarily disconnect your vacuum advance hose and put a timing light on it. Set it a 10 degrees advance, reattach the vacuum advance hose and try that.
WOW SO I HAND CRANKED MY ENGINE TO TDC AND IT DOESNT MATCH UP WITH MY TIMING MARKS AT ALL ITS AROUND 10-15 DEGREES OFF. ANYBODY SEEN THIS B4? WHAT COULD CAUSE IT? MAYBE MY CHAIN WAS PUT ON WRONG?
I thought you have already eliminated the timing chain with a new set.
When you rebuilt it did you install a new set,and had it jumped when you changed it again.
all true numberdummy except for the fact that there are three bolts holding the pieces together so that 1 does NOT "walk away". how can my timing marks be off though? if the harmonic balancer is placed only 1 way with the key? all my emmisions pumps and sensores were torn out when i bought the truck. to get tdc i used the old fashioned pencil method then pulled my valve covers off to check valve placement.
all true numberdummy except for the fact that there are three bolts holding the pieces together Uh huh, yeah right so that 1 does NOT "walk away". how can my timing marks be off though? if the harmonic balancer is placed only 1 way with the key?
Take a GOOD look at the balancer, kiddo...and you will see the rubber spacer poking out between the damper and pulley.
The three bolts do not hold the balancer/pulley together.
The three bolts are used to attach outer pulley(s) to the balancer.
Depending on what accessories (P/S, A/C, T/E, two belt alternator pulley) are installed, there may be one outer single sheeve pulley, or there could be a double or even a triple sheave outer pulley.
Over 35 years, I sold 100's of harmonic balancers, you wanna know why?
Because, the outer pulley SEPARATES from the inner damper...due to the fact that...over time...the rubber spacer cracks apart.
The outer ring on the balencer is pressed on with some sort of rubber in between, they can walk and it is very common for them to.
It should be very easy to time it by ear good enough to determine if timing is your problem.
check my balancer and the rubber piece is just dandy. timing it by ear does no good i can get super smooth idle but when i put into drive and step on the gas i get constant backfire and no power like i used to
