EGT temps
Old Jan 7, 2010 | 12:23 AM
69cruiser's Avatar
69cruiser
EGT temps
what are the normal temps u guys get driving i have a 4inch downpipe and a 5 inch exhaust with a predator tune at 60 that i cant get off my cpu
Old Jan 7, 2010 | 12:27 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
You will find that your temps vary due to ambient are and sometimes fuel quality/mix. Usually you will see about 600*F-800*F crusing at 65mph. Turbo, injectors, and intake can make a difference as well.
Old Jan 7, 2010 | 12:33 AM
69cruiser's Avatar
69cruiser
im just wondering cause i was cruising at 70 and my temps were at 400 and as soon as i let of the pedal it would drop down to 200 i was just wondering if my gauge is going bad
Old Jan 7, 2010 | 12:34 AM
Riffraff Diesel
PREMIUM SPONSOR
It could be having issues, corrosion, or connection etc. What does it idle at?
Old Jan 7, 2010 | 12:37 AM
69cruiser's Avatar
69cruiser
when i stopped it tonight it went down to 200 rel quick i was punching it on the fwy and i got it up to 600 at 80
Old Jan 7, 2010 | 12:49 AM
Riffraff Diesel
PREMIUM SPONSOR
What gauges are they? What did it use to idle at?
Old Jan 7, 2010 | 12:55 AM
69cruiser's Avatar
69cruiser
autometers i had them for 4or 5 years i believe when i would start the truck up it idle at 200
Old Jan 7, 2010 | 08:40 AM
white Buffalo's Avatar
white Buffalo
Just to clarify, where is your EGT probe located - pre turbo or post turbo?
Old Jan 7, 2010 | 08:47 AM
Ponyboychris's Avatar
Ponyboychris
Good question. If it's pre-turbo then you are seeing too low of readings which can be a bad gauge, bad ground, corroded wires, bad probe, etc... You should be seeing about 300 degrees at idle or when you lift off the go pedal, it should slowly return to 350 or 400 and not drop to 200.
Old Jan 7, 2010 | 09:52 AM
Riffraff Diesel
PREMIUM SPONSOR
Very good question. That should have been one of my first
Old Jan 7, 2010 | 10:42 AM
TRAINHORNMAN's Avatar
TRAINHORNMAN
Is it better to have it pre or post turbo?
Old Jan 7, 2010 | 11:38 AM
spdmpo's Avatar
spdmpo
Pre turbo, most people have it in the driver's side exhaust manifold. You want it as close to the head as possible.
Old Jan 7, 2010 | 11:41 AM
Riffraff Diesel
PREMIUM SPONSOR
x2
Old Jan 7, 2010 | 06:46 PM
69cruiser's Avatar
69cruiser
its on the manifold
Padlock
Oct 18, 2014 07:16 PM
UNTAMND
Jan 10, 2012 04:25 PM
05 f250 6 inch lift
Oct 26, 2010 07:51 AM
nurse47557
1997 - 2003 F150
Jan 15, 2005 10:02 PM
dave thomas
Oct 1, 2001 11:07 AM
