Steering wheel question
Old Jan 6, 2010 | 04:08 PM
73FordF100's Avatar
73FordF100
Does anybody know if the 67-72 F-series steering wheel will fit a dentside? I really like the look of them and was thinking about picking one up. Any info would be helpful. Thanks!
Here is a picture of one, but i'm not sure if that is a 73-79 steering column:
Old Jan 6, 2010 | 05:25 PM
kletus's Avatar
kletus
Same install kit from grant for both so I would guess the splines are the same.
Old Jan 7, 2010 | 05:24 PM
73FordF100's Avatar
73FordF100
Ok thanks that helps! I know it is a big steering wheel but I just love that newstalgic look! If it does fit, I might try to find a nice one at the junkyard if I can since it would be a whole lot cheaper than a reproduction one.
Old Jan 7, 2010 | 07:25 PM
Danny Stroup's Avatar
Danny Stroup
That is a nice look...much better than my big rubber horn blower.
Old Jan 8, 2010 | 06:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The THREE spoke steering wheel is the same: 1961/66 F100/250 2WD / 1967/70 F100/350 / 1966/73 Bronco / 1960/63 Falcon/Comet.
This steering wheel uses a horn button or a horn ring.
1971/79 F100/350's, 1974/79 Bronco's have a TWO spoke wheel with a horn pad.
1971/77 F100/350's use the same TWO spoke steering wheel (except 1975/77's with Cruise Control). The same wheel will be found on 1974/77 Bronco's.
1978/79 F100/350's and Bronco's use a different TWO spoke steering wheel.
Old Jan 8, 2010 | 09:02 AM
jb10's Avatar
jb10
the parts truck i picked up back in november has one it.
i'm not planning on using it. i can get you some pics if you are interested.
Old Jan 8, 2010 | 09:22 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I really like the look too, much better than the two spoke that's stock on the '73 Explorer I'm working on.
If it'll fit I'm going to put on a three spoke with a horn ring, much classier looking!
That's the nice thing about not doing a pure restoration, if I come across something I like better, I'm not locked into the "Well that's not original" mentality.
Old Jan 8, 2010 | 10:11 AM
73FordF100's Avatar
73FordF100
Thanks jb10, but according to NumberDummy, it looks like it won't fit. I wonder if thats a 61-70 F-Series steering column that is in the picture I posted that they put in a dentside.
Old Jan 8, 2010 | 11:05 AM
Furyus1's Avatar
Furyus1
I would bet that's what happened... Every 70's steering column I've seen (granted, it wasn't very many) was black - that one could have been painted red by someone, but it doesn't fit the blue scheme of that truck whatsoever...
Old Jan 8, 2010 | 12:03 PM
NumberDummy
I made no mention of any kind whether the THREE spoke steering wheel would fit...or not.
I merely corrected your post...because you said the (3 spoke) steering wheel is the same thru 1972. It is not.
The last year F100/350's used the THREE spoke steering wheel was 1970 (Bronco's used the THREE spoke wheel from 1966 thru 1973).
1971/73 TWO spoke steering wheels were originally available in Black, Blue, Red, Tan and Green.
In 1974, Ford obsoleted all these wheels except for black...which is the only color used 1974/77 & 1978/79.
Old Jan 8, 2010 | 01:13 PM
73FordF100's Avatar
73FordF100
Oh ok my bad NumberDummy, I wasn't reading it right. Thanks for the help!
Old Jan 8, 2010 | 08:03 PM
pat67shorty's Avatar
pat67shorty
That's a bumpside column. Look at the shifter/indicator.
Old Jan 8, 2010 | 08:16 PM
bulletsneverlie's Avatar
bulletsneverlie
I got one of those 3 spoke '67 steering wheels on a tilt column in the back right now. It'll go on the splines, but I'm not sure if the horn stuff will work. I wanted to use it so I could put on a Falcon horn ring, but I'm not sure if I'm going in that direction anymore.
Killgore
111
Dec 23, 2015 08:11 PM
Gary E
Sep 22, 2015 06:45 PM
csquire69
Vehicles for Sale
Sep 10, 2015 08:29 PM
FordF100man
Aug 6, 2015 06:00 PM
