North Carolina Chapter Join Chapter, Leader:Benztechnc
oil and plug problem
Old 01-07-2010, 07:06 PM
truckerboy's Avatar
truckerboy
truckerboy is offline
ok, i got a 81 f100 with a 300 engine. There is oil on the plugs, and it is fileing them out. Someone tod me that it may be the valve covers, but smeone else sad it is the rings. can any of yll straiten this out.
Old 01-09-2010, 05:22 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
check the compression, see how even they work out, then do a leak down test to see if the compression holds. I susspect worn, or broken rings
Old 01-09-2010, 05:37 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
No way a valve cover leak will foul a plug. Do a leakdown test on ALL cylinders and see what your have. You prob. have worn rings.
Old 01-09-2010, 07:47 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
oil fouled plugs is usualy a sign of worn valve guides or valve seals. broken or worn rings can do it but alot less common.
Jayybird
6.7L Power Stroke Diesel
30
05-24-2012 08:38 AM
uscgmkcret03
21
03-02-2012 09:07 PM
Powermonger
09-22-2011 09:00 AM
littlegreenford
Modular V8 (4.6L, 5.4L)
12-14-2008 11:29 AM
bulldogsf150
1997 - 2003 F150
08-05-2003 01:36 PM
Quick Reply: oil and plug problem
