frame ID
Old Jan 30, 2000 | 03:45 PM
craig_1's Avatar
craig_1
frame ID
I have a 74 f350 4x4, I think, frame and would like to varafy that it's a 1 ton and not a 3/4 ton frame. Were there any major differances? Where would I find the ID # and how would I decode it.
Thanks again, Craig
Old Feb 2, 2000 | 12:10 PM
wnelson's Avatar
wnelson
frame ID
Old Feb 2, 2000 | 08:08 PM
billathardcore4x4's Avatar
billathardcore4x4
frame ID
Hi Craig, to make this easy Ford didnt produce an F350 4x4 until 1979. To make things confusing they put a dana 60 axle under the front of some F250 4x4s but it was the low pinion axle with a divorced transfer case. I have 2 of these trucks, with 1 being a crewcab. The way to tell the difference between the early axles and the 79 and up is where the pinion gear enters the case.If it is below the centerline of the axle housing it will be an early version. If the pinion comes in above the centerline of the housing it is a 79 up. The vin of the truck will be stamped on the frame on the drivers side about 18" back from the front cab mount. If the # starts with F26 that designates the truck as being an F250 4x4. Back in the early 70s Ford called their 4x4s an F160 for 1/2 ton and F260 for a 3/4. Any time you see an early 70s 4x thats what the 6 stands for in the vin. Hope this helps thanx.
Old Feb 3, 2000 | 08:03 AM
jowilker's Avatar
jowilker
frame ID
Craig look on the top of the right side frame rail about where the front axle crosses under. The vin should be stamped there in that area.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
craig at ojo
25
May 10, 2009 07:39 AM
cokeb5
Dec 7, 2008 01:43 PM
CollinsCD
Aug 28, 2001 06:30 AM
72crew
May 11, 2000 10:31 AM
craig_1
Jan 29, 2000 12:42 PM
