Time for a plug change?
Old Jan 8, 2010 | 03:30 PM
bob schulz's Avatar
bob schulz
Gearbanger, at what time did the 4.6 heads gain more threads for the spark plugs? I read somewhere that a mere four threads held the plugs in, and then at some time, Ford changed the heads so that nine threads hold the plugs.
Most blown plug complaints seem earlier than '04.
Old Jan 8, 2010 | 03:59 PM
HYPO's Avatar
HYPO
Originally Posted by motown
A little tip to lower your chances of broken plugs. I ran Marvel mystry oil in every tank of gas a month prior to me changing mine. Every plug came out with great ease. MMO has mint oil, which disolves carbon, which will allow the plugs to turn in the head, without breaking. A couple of other people have done this and have had the same results.
I did the same and my plugs came out without a squeek or groan. In fact, they came out so easy, I was convinced I had broken them on the first 1/8 turn. On the last 3 or 4 plugs I just broke them loose, put the carb cleaner in, waited maybe 30 minutes, then unscrewed them pretty much by hand turning the plug socket. I did buy that socket with the attached extension, it seems to keep itself aligned in the plug well, preventing you from canting the socket which may be a contributer to breakage.
Don't know if it was the socket, the Marvel Mystry Oil, the carb cleaner, or the combination of all of the above. I do know that I was very pleasantly surprised at the outcome. I installed the Champion 7989's with the antiseize, truck is running well for 5000 miles now and life is good.
HYPO
Old Jan 8, 2010 | 04:24 PM
Gearbanger 101's Avatar
Gearbanger 101
Yeah, I believe in '03 they upped the thread count. It seems to have reduced the incidents of plug blow out greatly, but over on the Mustang board I moderate, there are still a few who've had to instal a Time-sert(s) in after having one or more work their way loose and screw the threads.
Old Jan 8, 2010 | 05:31 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
changem now or you'll be soooooooooooooooooorrrrrrrrrrrrrrrrrrrry!
Live long & prosper.
Borgia
Aug 7, 2017 04:48 PM
Mason R
Jul 16, 2017 09:21 AM
Mtlyon
Mar 9, 2017 10:55 AM
Gage2502
Dec 30, 2015 10:11 PM
tailbone
2004 - 2008 F150
Mar 11, 2013 08:43 AM
