help with 4-wheel drive
Old Jan 5, 2010 | 08:55 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by Monsta
The one you can turn is NOT locked, the one you can IS.
The one you can turn is NOT locked.
The one you can't is.
Forgot some letters and stuff before...
Old Jan 5, 2010 | 09:41 PM
EXv10's Avatar
EXv10
Originally Posted by JoeKan
just tried turning the locks on the front hubs, they are locked up and can't budge them. Now what?
Did you read my post above? https://www.ford-trucks.com/forums/9...ml#post8322598
Old Jan 6, 2010 | 01:57 AM
Monsta's Avatar
Monsta
Sit. Stay.
Brent, have you tried that on yours yet?
Old Jan 6, 2010 | 02:30 PM
JoeKan's Avatar
JoeKan
Mechanic said its frozen up. He can leave it locked in and whenever I want it out of 4/W I would have to take it in and have him do it. Or he can fix it right, like it's suppose to work but it will cost $770.
Old Jan 6, 2010 | 03:19 PM
myblkex's Avatar
myblkex
ouch... how much in parts does that come out to for the auto's ? If that's the case maybe just swap them out for manuals and then save the extra $500 for a nice new exhaust and remote start
Old Jan 6, 2010 | 04:53 PM
JoeKan's Avatar
JoeKan
It was going to be about $600 in parts alone. He said they've seen a lot of 4W that are freezing up. I'll have to wait before I get it fixed the right way.
Thanks for the help.
Old Jan 6, 2010 | 05:03 PM
Monsta's Avatar
Monsta
Sit. Stay.
Joe did you open the link I posted for you? You may be able to do it yourself if you're handy.
Old Jan 6, 2010 | 09:50 PM
Fully_Loaded's Avatar
Fully_Loaded
220 bucks for the replacement hub from Ford just did one on my F350. I have the same issue with my Ex. My right hub was froze up so I had my dad put pressure on it while the t-case was in 4x4 and I rolled forward. Rolled about a foot and it went in. I am assuming that these are auto manual hubs. I have the vacume leak on mine but both lines going into the hub assymbly have come off. I am going to fix them tomorrow. But when I put it in the air goes to defrost so the diagnosis above about a vacume leak is accurate.
Old Jan 6, 2010 | 10:39 PM
EXv10's Avatar
EXv10
No because they never needed it. How did you guess? If you see my original thread starter it says "just an idea" but my mechanical background tells me it will work.
Old Jan 7, 2010 | 12:39 AM
Monsta's Avatar
Monsta
Sit. Stay.
I did indeed read that thread when it first started. Didn't know if you had done it or not. ATF is a good idea. I've actually put some in my shock on my motorcycle to eliminate a groaning internal seal.
However, I was curious if you actually drilled yours or if you were just suggesting somebody else be the guinea pig.
Old Jan 7, 2010 | 12:47 AM
EXv10's Avatar
EXv10
Just looking for a guinea pig.
Old Oct 22, 2014 | 04:32 PM
OldGeezer513's Avatar
OldGeezer513
I have a 2003 Excursion 7.3 PS. I hear the hubs lock & unlock but 4WD doesn't work. Is there some kind of sensor on the transfer case that puts it in 4WD?
Misterunlimited
1997 - 2003 F150
Oct 1, 2015 12:54 PM
iTRanger
1983 - 2012 Ranger & B-Series
Apr 17, 2015 08:26 PM
tnco-op
Dec 8, 2014 01:39 AM
belldawg
Aug 16, 2007 10:35 AM
X GM GUY
Apr 6, 2005 10:14 AM
