4X4 clicking
Old Jan 4, 2010 | 04:08 PM
87bogger's Avatar
87bogger
4X4 clicking
I have a 1987 f150 4 speed. Recently I was driving down the road with my hubs locked (in 2wd) and i heard a clicking. I pulled over, unlocked the hubs and went on my way and didn't hear the clicking anymore. Then a couple days ago I had to put my truck in 4X4 and the front wheels were not spinning and all I heard was a really bad clicking noise (way worse than the one driving down the road). If anyone has ideas of what this may be, I'd love to hear them.
Old Jan 4, 2010 | 05:43 PM
Hitokori's Avatar
Hitokori
possibly a broke axle
Old Jan 4, 2010 | 07:52 PM
87bogger's Avatar
87bogger
but wouldn't that mean it would make the noise when it is in 2wd as well?
Old Jan 4, 2010 | 07:55 PM
Volvo92906's Avatar
Volvo92906
Doesnt spin in 2wd. hubs arent locked so wheels are just spinning on spindle.
Old Jan 4, 2010 | 07:59 PM
87bogger's Avatar
87bogger
but the hubs were locked. but i heard that that doesn't do anything bad for the truck..
Old Jan 4, 2010 | 08:00 PM
Hitokori's Avatar
Hitokori
every thing here says broke axle if its in 2wd with the hubs unlocked it wont turn
if u have the hubs locked they turn in 2wd
or u may have stripped hubs
Old Jan 4, 2010 | 08:10 PM
87bogger's Avatar
87bogger
ok thanks a lot.
Old Jan 4, 2010 | 08:13 PM
Hitokori's Avatar
Hitokori
look at ur hubs first....
Old Jan 4, 2010 | 09:26 PM
Mike1996F350's Avatar
Mike1996F350
Universal Joints may be going bad in it as well. I had a similar problem with a clicking noise from my drive shaft and it turned out to be the rear U-joint was going bad. I would look into those as well, since they do not spin when the hubs are unlocked.
Old Jan 4, 2010 | 09:34 PM
Hitokori's Avatar
Hitokori
yea that could be the case but since he had it in 4wd and the wheels wasnt turning and it was popping its more than likely stripped hubs or broke axle
Old Jan 4, 2010 | 09:38 PM
Mud-and-Guts's Avatar
Mud-and-Guts
Do you have auto hubs?
I had the same thing happen and it was the hubs so I replaced them with warn manual hubs.
Old Jan 4, 2010 | 11:38 PM
87bogger's Avatar
87bogger
I don't think it would be the u joints because they were replaced within the last 2 months. And my hubs are manual lock outs.
Old Jan 5, 2010 | 07:54 AM
Mud-and-Guts
Get in the truck and have someone listen from side to side when it is clicking.
Old Jan 5, 2010 | 10:28 AM
hillbilly469's Avatar
hillbilly469
Jack the rear end up and put it on jack stands, lock your hubs in, shift it into 4 wheel drive and put it in gear and have someone look from the side (so as not to get run over)to see which axle is turning up front while you are on the ready for the brake in case it would take hold. If the front drive shaft is spinning then one of the front axles should be as well unless your problem in in the diff itself. I had a pinion break behind the bearing once that prevented the axles from spinning. You have an open differential up front and the axle with the least resistance will be the one turning and it will also be the one with the problem. The passenger side uses a two piece axle that could be stripped if not that and the axle isn't broken its a stripped hub or incorrectly installed hub.
broncoking1994
1978 - 1996 Big Bronco
Jun 1, 2013 03:24 PM
GeneralC.
Jun 3, 2008 07:27 PM
geneb11
21
Jul 22, 2003 08:21 AM
