Does anybody know how to repair or fix a hole in the ceiling the size of your pinky? It will be raining here in 2 days, and need to get this fixed. Thank yall for your help.
Reason: better
Roofing patch tar, or waterproof marine body filler. That's what I just recently used to stop water splashing inside an aging Toyota so I wouldn't have to sponge the carpets dry after driving in the rain.
I patched a bunch of roof rack holes in my wife's Wagoneer with foil backed rubber tape, applied from the inside. cut the small patch, stick it on, and heat lightly with a propane torch before burnishing it on. You'll find a use for the rest of the roll real quick.
