HIGH BOY
Old Feb 17, 2000 | 08:36 AM
DOG's Avatar
DOG
HIGH BOY
I HAVE A 74 3/4 TON 4 4 WITH A 390.MY FIRST QUESTON IS WHAT IS A HIGH BOY.MY SECOND QUESTON IS ABOUT THE 390,IT HAS A TAG ON THE SIDE OF THE BLOCK THAT IT HAS BEEN BORED 40 OVER.I BELIVE THIS TO BE A FACTORY TAG.IT ALSO HAS FACTORY CHROME VALVE COVERS AND 4 BARREL INTAKE.I KNOW THE 390 CAME OUT OF A EARLY 60 GALEXIE.I WOULD LIKE TO KNOW MORE ABOUT THIS MOTER,DID FORD MAKE THESE FOR A CERTON REASON,AND SINCE FORD BORED IT HOW MANY CUBES IS IT NOW. THANKS FOR ANY INFO
Old Feb 17, 2000 | 12:53 PM
jowilker's Avatar
jowilker
HIGH BOY
Dog I don't think Ford bored that engine for new install. You might have a Ford reman. You could have a car engine installed, and the chrome could be aftermarket, or from another engine.
High Boy is a name picked up because the truck is so high off the ground. It is a street name, and is not official from Ford.
Hope this helps a little.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Feb 17, 2000 | 01:16 PM
Nate_64's Avatar
Nate_64
HIGH BOY
Dog,
You can figure the current displacement with this simple(HA HA) formula:
calculate the current bore diameter by adding .04 inches to the original bore diameter. Divide this number by two, then square the quotient. Multiply this number by pi (3.1415927- of course, use only significant digits). Then multiply this product by the length of stroke. That will give you a volume displacement per cylinder. Multiply by 8 and voila! there is your current displacement.
the formula is: [(pi x radius)squared]x heighth
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Old Feb 17, 2000 | 01:24 PM
Nate_64's Avatar
Nate_64
HIGH BOY
My bad- you should not suare the radius until after you multiply it by pi.
so, it would be [(bore x pi)squared] x stroke
I'd figure it for you, but I don't know the bore and stroke on these engines.
Nate
1990 F-150 5.8L
Old Feb 17, 2000 | 06:55 PM
Nate_64's Avatar
Nate_64
HIGH BOY
Okay, I became obsessed with getting this right. The description I gave in post #2 is correct, but the formula is not. Post #3 is alltogether wrong, so disregard it.
Anyway, I found the specs and did the math. According to what I found, a 390 had a bore of 4.05 in and a 3.78 stroke. With it bored .040 over, you would increase displacement to 397 cubic inches.
Just wanted to clear it up, and apologize for the confusuion. Geometry was too long ago!
So, for one last time (to get it right)- figure displacement by squaring the radius of the bore, multiply that by pi (3.14), and then multiply the product by the stroke.
4.05 .040= 4.09
divide by 2 (to get radius)= 2.045
2.045 x 2.045= 4.18 (use only significant digits)
4.18 x 3.14= 13.13
13.13 x 3.78= 49.63
displacement is 49.63 cu. in. per cylinder
multiply by # of cylinders, and you get about 397 cu. in.
I'm sure I became more concerned about this than anyone else, but maybe this will help.
Nate
1990 F-150 5.8L
Old Feb 17, 2000 | 09:33 PM
jmg7184's Avatar
jmg7184
HIGH BOY
USArmyTaterness
Jul 28, 2009 03:58 AM
f150v602
Louisiana Chapter
Feb 16, 2008 09:54 AM
kawa
27
Aug 25, 2007 12:39 AM
2classics
Offroad & 4x4
Aug 8, 2007 09:31 PM
genma
Dec 10, 2001 07:38 PM
