Loud Knock
Old Jan 7, 2010 | 08:29 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by Flyin5
Anyone have a flat plate i can borrow to see if my pushrods are bent?
What cylinder was that?
Old Jan 7, 2010 | 08:48 AM
clux's Avatar
clux
Hydrolock possibly?
Old Jan 7, 2010 | 09:50 AM
Flyin5's Avatar
Flyin5
Big Poppa- It did sit and idle for about 15-20 mins, then shut off for 10 and ran again for the same time period.
MADVAN- running 5w 30 amsoil synthetic
Happened on cyl #2
And yes it seems it did hydrolock the first time when i pulled the injectors.
Old Jan 7, 2010 | 01:10 PM
bigsteve1969's Avatar
bigsteve1969
wonder how the lifter looks.
Old Jan 7, 2010 | 01:24 PM
Flyin5's Avatar
Flyin5
good question. Oil pressure still reads on the gauge, if the lifter came apart it would read 0 or low correct?
Any small tips for installing the new push rods? I know about the copper end going up (right?) anything else i should know? Tried researching but havnt found much.
Old Jan 7, 2010 | 01:33 PM
MADVAN's Avatar
MADVAN
IH spec is motor clocked at 11 for pushrod/rocker install.
Just align the damper mark with the cps index.
Bill
Old Jan 8, 2010 | 08:12 AM
Kwikkordead
Bill
I did notice a "timing mark" on the damper.
Is that what you are talking about here?
And for all eight, or do you install some, then rotate the crank 360 and do the rest?
Old Jan 10, 2010 | 07:52 PM
Flyin5's Avatar
Flyin5
I was also wondering that. Mostly I'm sure you just want to make sure you are at TDC or at least somewhere close where neither valve would be open.. correct?
Old Jan 10, 2010 | 10:15 PM
Ford79's Avatar
Ford79
As far as I know, you want to be at TDC on the cylinder you are installing the pushrods in. Not sure about lashing them, do the PSD's have hyd. lifters? If so, isn't it usually 1/2 turn past zero lash? Maybe I'm just thinking gassers here.
Old Jan 11, 2010 | 01:06 AM
SpringerPop's Avatar
SpringerPop
Powerstrokes are, indeed, hydraulics.
Pop
BearNDownArchery
1997 - 2003 F150
May 11, 2012 07:13 PM
Diesel-Fanatic
Jan 4, 2009 07:05 AM
ciscofreak
Dec 4, 2007 10:16 PM
pacllama
38
Feb 12, 2007 08:20 PM
Celicadude
Sep 25, 2006 11:50 AM
