4R100 fluid
Old Jan 3, 2010 | 10:03 PM
white Buffalo's Avatar
white Buffalo
Need Mark K. to look at the specifications. Says it is compatible with Mercon V applications, but it is also listed as SP.
http://www.nulon.com.au/products/Ful...mission_Fluid/
Old Jan 3, 2010 | 10:08 PM
mueckster's Avatar
mueckster
I compared the specs to my Mobil 1 Syn Multi-Vehicle ATF and it looks very similar. It does seem to be an acceptable alternative.
Old Jan 3, 2010 | 10:10 PM
ChunderDownUnder's Avatar
ChunderDownUnder
100% Synthetic Multi Vehicle Automatic Transmission Fluid - Nulon Products Australia
Whats SP ?
Old Jan 3, 2010 | 10:26 PM
mueckster's Avatar
mueckster
MERCON® SP Automatic Transmission Fluid
Motorcraft® MERCON® SP is a premium-quality fluid designed, engineered and recommended by Ford Motor Company specifically for use in Ford, Lincoln and Mercury vehicles that require MERCON® SP type fluid. This product also provides excellent performance in electronically controlled automatic transmissions. Check Owner’s Guide or Workshop Manual for correct applications
Motorcraft® MERCON® SP is manufactured with premium base oils and specially designed performance additives, which provide excellent shifting characteristics at high and low ambient temperatures, excellent thermal and oxidation resistance. It provides wear protection and inhibits the formation of gum, sludge, lacquer and foam. It also provides protection against rust and corrosion. MERCON® SP is friction modified for smooth transmission operation while guarding against transmission shudder
Specifically designed for improved durability and torque handling capacity in TorqShift™ transmissions
Do not use in transmissions requiring MERCON® V, MERCON® LV, Continously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid, or Type F Fluid
This is the part that is confusing because the Nulon ATF specs say it will work in both applications.
Old Jan 3, 2010 | 10:40 PM
white Buffalo
Roland hit it in his post. The biggest differences between SP and the other Mercon specs is the viscosity. SP has a lower viscosity than the Mercon V fluid. I'm not saying that the fluid will not work - just need to make sure it's not too low for the 4R100.
Old Jan 3, 2010 | 10:43 PM
ChunderDownUnder
Thanks guys. I will email Nulon.
Old Jan 3, 2010 | 10:53 PM
Bluebronco85's Avatar
Bluebronco85
Mercon V will work in the 4r100 but i was told by a trans mechanic not to mix the two. Don't know what will happen but i have since heard it by several not to mix so i went back with the traditional mercon when i put in my transgo and flushed the system. Don't know if i would take that to the bank but thats my .02
Old Jan 3, 2010 | 10:58 PM
white Buffalo
I would also send Mark Kovalsky (post #10) a PM to get his input. What caught my eye was that the Nulon fluid states good for Ford Mercon V and SP applications.
From the info I have read Mercon V requires a minimum viscosity of 6.8, the SP requires a viscosity of 5.5 to 6.
The Nulon website shows it has a viscosity of 7? So how can it be used for both applications? Just want to make sure before you make the purchase.
Old Jan 4, 2010 | 08:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by aldridgec
So what happened to II III and IV?
They never issued II, III, or IV. I don't understand why.
Old Jan 4, 2010 | 08:39 AM
clux's Avatar
clux
Because it had to be bigger and better than Dexron III.
Old Jan 4, 2010 | 11:58 AM
h2guy's Avatar
h2guy
Thats another possibility Chunder. If you can find a more economical fluid locally, marked Dexron III, its the same as MERCON, and could be used.
I still use only MERCON and find it widely available under the Castrol, Pennzoil, Valvoline, etc. (and other) brands.
FWIW.
Old Jan 5, 2010 | 12:52 AM
ChunderDownUnder
Still waiting to here back from Nulon.
Next question. If I follow the steps here
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles will that flush the all the old oil out (mind you it is only six months old) and leave me with clean synthetic?
Old Jan 5, 2010 | 03:49 AM
  #28
Mark Kovalsky
Yes, that will flush out about 95% of the old oil. The only way to get all 100% is to tear the trans down and wash all of the parts.
Old Jan 6, 2010 | 08:55 PM
  #29
ChunderDownUnder
Is this the return line I need to connect the clear hose to for the flush ??
Old Jan 6, 2010 | 09:06 PM
  #30
schlepprock250's Avatar
schlepprock250
Originally Posted by ChunderDownUnder
Well my local Ford dealer stocks Motocraft MerconV in quart bottles only. You talk about being expensive. Here one quart cost $ 20.50 x 18 qts lol, forget it.
Heck,if its that high down under,maybe we can check shipping and ship a good choice to him.
