FUEL LEAK
Old Jan 2, 2010 | 11:18 PM
fordpride's Avatar
fordpride
FUEL LEAK
i have a fuel leak on the back of the fuel pump were the metal lines come out of the pump. what kind of seal is in there o-ring or tin washer and can i just buy that seal
Old Jan 3, 2010 | 01:17 AM
jeep1947's Avatar
jeep1947
If you mean leaking at the banjo bolt try to tighten it up first 1 1/4 box end of combination wrench. If it still leaks there is a metal gasket on each side of the fitting get them from Ford. Or u can take them off and use a smokey flame on a torch to soften them up then reinstall. Hope this helps. Jeep
billdoss2
Dec 1, 2016 01:56 PM
73 ford guy
Sep 16, 2015 09:06 AM
sparke454
13
Sep 27, 2008 03:28 PM
mchild
Feb 4, 2003 05:57 PM
mgriffin
Dec 11, 2002 06:30 PM
