Sponsored by: Real Truck
External fuel tank fitting leaking
Old Dec 11, 2002 | 07:14 AM
mgriffin's Avatar
mgriffin
Was un-sure of the best place to post this question.
I have an external fuel tank with the 12v pump mounted on the top. The threads where the pump and fill tube go into the top are leaking. The instructions that came with both the tank and pump indicate using teflon tape...I don't think its sealing good enough. Yes, I have re-wrapped them even with more turns around the thread.
My question is will regular plumbers thread compound work better? Will the diesel fuel eat it away? Is there something better that I don't know about?
Old Dec 11, 2002 | 07:38 AM
FortyFords's Avatar
FortyFords
You need to get some "Blue Goop" you can get it at a plumbers supply house .We used it on everything known to man! acids ,chemicals ,diesel fuel ,gasoline, perchlor you name it !
But chk the thread bung on your tank to make sure it's not cracked!
This stuff will seal it but,the stress of fitting (tapered threads) will
keep stress in the area.
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Dec 11, 2002 | 08:56 AM
mgriffin's Avatar
mgriffin
Thanks, I am headed for US Supply at lunch. "Blue Goop"
Old Dec 11, 2002 | 03:42 PM
4x4x4x4's Avatar
4x4x4x4
I have been told that teflon tape is more of a thread lubricant than a thread sealer.
If you can't find "Blue Goop",Loctite makes some good petroleum resistant pipe "dope".
Old Dec 11, 2002 | 03:50 PM
FortyFords's Avatar
FortyFords
Yes! loctite does I used some of there stuff on stainless steel fittings awhile ago!
Rich
"All Levers"
Old Dec 11, 2002 | 06:30 PM
infinity's Avatar
infinity
Jymmm
21
Apr 3, 2019 12:52 AM
Brain's 97 Diesel
Nov 4, 2016 06:27 PM
Icthus in AK
6.7L Power Stroke Diesel
Jun 26, 2015 06:27 AM
master link
Aug 24, 2006 11:19 AM
mgriffin
Oct 1, 2002 10:39 AM
