HPOP Reservoir
Old Jan 2, 2010 | 08:48 PM
genbryan's Avatar
genbryan
HPOP Reservoir
So has anyone ever changed the oil in their HPOP reservoir while doing a regular oil change?
Old Jan 2, 2010 | 09:58 PM
Hussler's Avatar
Hussler
Some do, most don't. I think if ford thought it was necessary they would of made it easy. My thought is next oil change I might try it as I have heard the bottom of the reservoir can get very sludgy. No actual proof on my part, just from reading threads over the years. Anyway, I guess it would be hard to get it all out anyway.
Old Jan 2, 2010 | 10:10 PM
blue66tang95f150's Avatar
blue66tang95f150
I just did it tonight. First time I have done it. The oil wasn't any different than the oil out of the motor. So I may not do it again. I also purposely left it low to see how quickly the engine fills it back up. I ran it for about 2 minutes and it was full again. So I know the engine oil cycles through it fairly quickly. Depends on how annal you are I guess.
Old Jan 2, 2010 | 10:17 PM
Hussler's Avatar
Hussler
So your are saying you did not fill it up and it started right up?
Old Jan 2, 2010 | 10:50 PM
genbryan's Avatar
genbryan
Well I'v read up and seen visual aids that there is a poppet type valve that allows the engin oil to run directly to the reservoir quicky for the cold startups, but it is un filtered and when the pressure on both sides equalize the valve closes and only allows filered oil into the rservoir.So I would fill it back up after daining it. So how much time did it take to get that reservoir opend up?
Old Jan 3, 2010 | 01:57 AM
blue66tang95f150
No Filled it up, I just left it about an inch from the top. I wanted to see if it would get the fresh clean oil I just put in the motor.
khntr
13
Jun 25, 2021 08:44 AM
wstanley
Jan 17, 2015 02:12 PM
FUJINAMI1293
May 25, 2013 01:41 PM
FUJINAMI1293
18
May 4, 2013 08:10 PM
bigblock501
15
Dec 2, 2011 06:37 AM
