'66 and '76 Radiators Compared!
Old Jan 2, 2010 | 08:09 PM
banjopicker66's Avatar
banjopicker66
Check my gallery for the new radiator I put in, for pictures comparing it to my original '66 radiator for a 352.
The radiator I got was for a '76 with a 460. Look at how exact it is. All the holes and dimensions line up. By the way, I have a 460 in there now - but the 352 hoses hooked straight up to the original radiator.
I paid $162 from Advance Auto with a limited lifetime warranty.
Funny thing is, they wanted $285 for a radiator for my '66 with a 352, and it didn't even come with the cooler!
Now, I am betting that if you unbolted and switched around the side mounts (yes, the side mounts are bolted, not soldered), you could put this in a '65 -
I bet you could!
My next step is to see if my old radiator (the original one) will fit into the '64 repop core support I have ready (someday) to put in my Slick. I am also betting that it will as well.
Anyway, hope this helps!
Old Jan 2, 2010 | 08:34 PM
Bill W's Avatar
Bill W
all i get is a red X in your gallery
Old Jan 2, 2010 | 08:54 PM
banjopicker66
Try again? They are all there - not sure why you cannot see them.
Old Jan 2, 2010 | 09:19 PM
Old_Crow's Avatar
Old_Crow
So, can anyone tell me if the '61 core support is the same as the '65-'66. I'm needing to find a radiator for the 302 conversion in my '61.
Old Jan 2, 2010 | 09:26 PM
Bill W's Avatar
Bill W
found them, they are in your albums.
they have too many places to store pictures on this site there's the gallery the garage and the albums. the rad is very close, only difference i see is the bottom hose size looks smaller for the new rad.
Old Jan 2, 2010 | 09:28 PM
Bill W's Avatar
Bill W
no they are not, but they can be interchanged with some basic mods.
i'm not sure about the rad you need.
Old Jan 2, 2010 | 09:44 PM
Old_Crow's Avatar
Old_Crow
That one there looks like it might work. Outlets are in the correct positions and it's got a tranny cooler.
Old Jan 2, 2010 | 09:50 PM
Bill W's Avatar
Bill W
there you go, get one for a 76 truck w/460 for 168 bucks. beats the 400+ i spent to have mine restored!
Old Jan 2, 2010 | 11:00 PM
dman2008's Avatar
dman2008
You got a great deal I had mine from a 75 F150 which had a 460 and it cost me $500 to get it recored, very nice deal. I also added an additional tranny cooler for extra cooling for $40.
D
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Jan 3, 2010 | 03:21 AM
IsoGrifo's Avatar
IsoGrifo
had an aluminum one built for me for 370! I'll post some pictures of it in my gallery at some point
Old Jan 3, 2010 | 06:59 AM
banjopicker66
Iso, you are correct about the outlet. It is smaller, but the radiator came with a rubber sleeve to act as an adapter so I used it, and it worked out just fine.
Also, I had to use the barbed fittings from the original cooler on the new radiator, but the radiator came with the step-down fittings as well.
Sure it isn't "original", but it bolts up and works like one!
PS: It is a lot lighter too - possibly half the weight of the original.
Old Jan 3, 2010 | 11:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The radiator I got was for a '76 with a 460. That's what the parts store told you, but...
Since you posted pics of this radiator, I can tell you it's not from any 1975/79 F100/350 with a 460...as original.
1973/74 F100/350 460's with Xtra Cooling or A/C and ALL 1975/79 F100/350's with 460's came with the 4 row Super Cooling radiator (D3TZ8005G) as standard equipment.
Its top tank is 5 inches wide, it's actually wider than the core itself.
This exact same radiator was an option on 1973/74 F100/350 460's (without Xtra Cooling or A/C) and 1973/76 F100/350's with 360/390's.
The radiator you bought is: D3TZ8005B. It was used in 1973/74 F100/350 460's (standard cooling only) and 1973/76 F100/350's with 360/390's with Xtra Cooling or A/C.
If you did have the Super Cooling radiator, you would discover very quickly it will not fit in any 1966 without modifying the core support.
When the Super Cooling radiator is present, the core support is different, because the Super Cooling radiator is taller and has a larger opening radius.
This means you would have to trim the core support and then drill new mounting holes in it.
Becky_is_a_66
29
Jul 4, 2016 07:35 AM
wagonerkl
Jan 19, 2010 01:00 AM
ironwrkr
Aug 20, 2009 08:06 PM
banjopicker66
Jul 12, 2005 05:34 AM
Putt
Jun 9, 2004 09:27 AM
