Rust
Old Feb 20, 2000 | 11:34 AM
David's Avatar
David
Rust
I have some rusty places on my highboy. I have read in past post that some of you have used products that turn rust into a primer or something like it. I could use the names of some products to use. Also, Can someone tell me how the drip rails are fastened to the cab. I am not a body man and could use the help in whether to get a body shop to fix my problem or if it could indeed be a do-it-myself kind of job. Thanks.
Old Feb 20, 2000 | 09:13 PM
MSTRAWN's Avatar
MSTRAWN
Rust
David, I have used two different products, one was called EXTEND, purchased at Ace Hardware, the other was purchased at AUTOZONE but I cant remember the name of it. I just asked the salesperson for something to kill the rust. Both products worked quite well. They both turned a purple or black when cured and both stopped the rust.
Old Feb 21, 2000 | 06:46 AM
PetesPonies's Avatar
PetesPonies
Rust
It depends where the rust is. There are some good rust paints that will seal the surface rust permanently, like POR15 or Miracle Paint. If this rusted area will show, then this paint can be primed before it sets completely. Tell me where the rust is and I'll tell you how to fix it.
Pete's Ponies Mustang RUSToration & Performance
Old Feb 21, 2000 | 05:13 PM
David's Avatar
David
Rust
The rust is located between the drip rail and the cab. There are two small holes. One is the size of a nickel and the other is the size of a #2 pencil. Thank you for any and all help you can give.
Old Feb 21, 2000 | 05:14 PM
sparky's Avatar
sparky
Rust
