My 40 pickup
Old Oct 19, 2011 | 09:19 PM
  #61
Flathead Red's Avatar
Flathead Red
I am on a roll! I got off work early so I jumped on the truck as soon as I got home. I removed the leaf springs first
Then set off cutting the old spring perches off the frame.
That took the majority of my time and sawzall blades! I then removed the poly gas tank and drained it.
My next plans are to remove all the fuel line as I am going to replace it anyway and then remove what is left of the exhaust. It is going to be in the way as I work around the rear end and it too will be replaced.
More later, Red
Old Oct 19, 2011 | 10:30 PM
  #62
Bill W's Avatar
Bill W
nice to see ya making some progress!
Old Oct 25, 2011 | 10:36 AM
  #63
Flathead Red
Here is the latest. I got the spring perches in.
I was really impressed with the fit and ease of installation. The directions were not so easy to figure out. I read them over about ten times to make sure I got it. I had no issues during the installation so far and everything fit as it should. The rear perches needed to be finessed a bit (I clamped it in several locations to get it to the contour of the frame) to get the front mounting holes to line up.
The upper shock mounts went in pretty easy as well. The rear end had some square tubing as lowering blocks, so I ordered new aluminum lowering blocks from Speedway. They should be here in a couple days and I can get the rest of the rear end buttoned up. Barring any issues, I hope to have mock up complete this weekend and have it back apart and ready to paint. I am ordering some rust encapsulator and chassis black to finish it off.
Red
Old Oct 25, 2011 | 04:56 PM
  #64
mj40's's Avatar
mj40's
It's a good kit and rides well also.
Old Oct 26, 2011 | 09:23 PM
  #65
Flathead Red
I got everything done for the mock up that I can minus lowering blocks which should be here tomorrow. Today, I worked on cleaning up the rear pumpkin and rolling it back into place while hand tightening the rear shackles.
I might have to cut a small section in the rear cross member for shock clearance but that is minor. I look forward to getting the lowering blocks to get it completely buttoned up.
More to come!
Red
Old Oct 27, 2011 | 06:23 AM
  #66
jarod17's Avatar
jarod17
Coming along nice. Keep up the good work.
Old Oct 31, 2011 | 11:57 AM
  #67
christurney77's Avatar
christurney77
great job!!! keep showing new pics.
Old Nov 7, 2011 | 09:14 AM
  #68
Flathead Red
Thanks, I think it is going to be much better myself. In my last steps of mock up, I cut one of the U bolts to short as I misread the directions and put the bottom shock mount in the wrong place. So I ordered two new U Bolts and my chassis paint and stopped working until that came in. It all came in friday so saturday, I finished cleaning the underside of the frame and coated the rear section with Rust neutralizer. It has to sit for 48 hours so I was essentially done with that for a while. I painted the new brackets and the rear end with the chassis paint and it looks awesome! My school starts today so my work will slow down again. Tonight I will paint the rear section of the frame with rust encapsulator so hopefully I can weld in the box plates this weekend.
I forgot to take some pictures of the frame before I started painting the rust encapsulator. The rust neutralizer literally turned the frame black.
The brackets came out nice as well. I can't wait to get this all back together!
Red
Old Nov 10, 2011 | 10:03 PM
  #69
alittle40's Avatar
alittle40
I went a little bit different on my rear shock setup by removing the cross member behind the rear end housing. The reason being, I needed more room for shocks to avoid them binding and it provided me with mounting anchor for the gas tank. I saw no reason to retain the cross member as it did nothing for the build. You be the judge, check it out.
[IMG][/IMG]
More to come!
Red
Old Nov 11, 2011 | 08:25 AM
  #70
Flathead Red
I think if I had an X member it would be no issue to remove the rear cross member. But I don't have one and the rear cross member provides the ridgidity in the frame I need. Plus I see no binding in my shocks with the mounts as they are. I made some small half oval cuts in the cross member for shock clearance. I was considering replacing the X member with an after market one but am unsure right now. The front clip is 74 Nova and was grafted to the frame all the way back to below the cab. I want to replace that set up with an IFS but am not sure if that frame will work due to all the grafting. I will tackle that after the rear end is completed. Thanks for your inputs. It helps to have others opinions and tips.
Red
Old Nov 11, 2011 | 09:09 AM
  #71
mj40's's Avatar
mj40's
Looking good and much improvement. . I leave my x members in for the shock mounts and it also makes a great place to mount a trailer hitch from the old spring mount holes.
Old Nov 11, 2011 | 04:22 PM
  #72
Flathead Red
I am having a dilema right now and partly due to not knowing. The front portion of the frame was grafted from a 74 Nova. The grafted section extends to below the cab. I want to scrap the front suspension and install an IFS. Additionally I want to add in the X member whether it be a bolt in tubular one or one close to stock. I found that fatman fabrications does a front frame that grafts into damaged frames. My dilema comes from "do I just scrap my existing frame and but new rails, front crossmemer and X member or do I attempt to remedy the existing frame? I need to get the cab off and strip the frame down and find out the extent of the graft first. Just thinking out loud really. I welcome all inputs.
Red
Old Nov 28, 2011 | 12:29 AM
  #73
jotram's Avatar
jotram
Red
I'd say see how the rest of the frame looks who knows what other crafty things the P.O did. It would probly be lots more work to strip everything off and put on a different frame! if the rest of the frame looks good I would try and fix the existing frame shouldnt be a problem .On the other hand if your going to strip it anyway I would look for a new frame good luck post some pictures
Old Nov 28, 2011 | 12:35 AM
  #74
jotram's Avatar
jotram
what axel are you using under there flathead red?
Old Nov 28, 2011 | 10:08 AM
  #75
mj40's's Avatar
mj40's
Red
So the front suspension in your mind is junk? It has had the X members removed and the rear springs were poorly installed. Before spending any more time and money on this frame, you seriously need to check it all out and start lookig for a better frame. The car frames from 35 to 40 are the same and 40/41 piclkups as well. I only paid $300 for my project frame and way ahead in costs from starting over like yours. Even the S10 pickup frame is a good option.
