05 6.0 w/ Plow on having cooling issues
I've read through all the tsb info and quite a few threads, but it hasn't answered my question yet. On the highway my truck has been getting hot when I'm running with the plow on. I've been plowing with this same truck for 5 years now and I haven't had any cooling issues until now. It seems like the clutch fan isn't kicking in and it lets the truck get too hot. I have the plow prep package which means I have the HD clutch fan.
Has anyone else had this happen? Think it could be a weak clutch fan? Also, the service manual says you have to pull the radiator to pull the fan clutch. Is this true or is it doable to get around it. It looks pretty tight. I already have the fan clutch wrenches etc.
It doesn't get hot at all when I'm doing anything else so I think the coolant is flowing ok. I just took a ride and left the plow a little lower than usual and all was ok. Its weird that this just started hapening and I'm not hearing the clutch fan engage when the temp creeps too high.
That's what its looking like right now, but I'm not convinced yet. Why would it be ok for five years and then all of a sudden start causing a problem? Also, when it was getting hot the last twp times dropping the plow didn't cool it down.I might not have waited long enough to cool down before pulling off the highway.
