429 vacuum junction block needed
Old Jan 2, 2010 | 01:46 PM
MikeB 88's Avatar
MikeB 88
I pulled the 1/4" hose off my junction block so I could get some vacuum readings. My problem is that the brass nipple pulled pulled out of the junction block also. The nipple is lost, so I can't put it back in the block. The junction screws in on the rear of the intake manifold and has 1 fitting that runs to the brake booster and the 1/4" fitting that supplies vacuum for the rest of the car. Does anyone know where I might be able to get one?
Thanks,
Old Jan 5, 2010 | 04:14 AM
johncart's Avatar
johncart
junction block
check the thread size into the block probably just a pipe thread...look at industrial catalog for air fittings...i am sure you can make something up
Old Jan 6, 2010 | 08:04 AM
MikeB 88's Avatar
MikeB 88
Got lucky and was able to find the missing nipple. I may try to J&B Weld back into the block.
psi3000
Dec 17, 2020 07:04 AM
bills86f150
Apr 11, 2012 07:23 PM
hojolabo
Aug 12, 2011 09:11 PM
JCastellaw
1966 - 1977 Early Broncos
Dec 27, 2007 01:02 PM
RaleighDad66
Jun 29, 2005 09:41 PM
