2000 Ford Excursion Front Squeaks
Old Jan 1, 2010 | 10:28 PM
Pat Ricchiuto's Avatar
Pat Ricchiuto
My truck would squeak when I would start, stop or turning.
Anyone who has had this frustrating problem understands my pain. I complained to Ford everytime I took it in. I finally fix it myself. I tighten
my leaf spring bolts, checked my tie rods, ball joints, I replaced both
hub assemblys put new spacers in my leaf springs. Still squeaking.
Until I read a thread about the front mounting bolts under the carpet
by your feet. I took them out added a rubber washer on it from my garden hose and put wheel bearing grease on them. Then went under the truck
and sprayed lithium grease between the rubber mount and the frame. Put
more grease up in the hole where the bolt goes and tighten them back
up and no more squeaks.
There are 10 of these Body mounts on the truck.
Hope this helps someone.
Old Jan 1, 2010 | 11:09 PM
Fomoko1's Avatar
Fomoko1
Season`s Greeting and welcome to FTE Pat.
Post this tip in the Excursion forum: Excursion - King of SUVs - Ford Truck Enthusiasts Forums
Also check out your local IL chapter soon: Illinois Chapter - Ford Truck Enthusiasts Forums
Old Jan 5, 2010 | 03:56 PM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site.
El_Coqui
New Member Introductions
Nov 10, 2013 10:50 PM
x 2000
Apr 16, 2013 02:22 PM
michaellhodges
Oct 25, 2006 01:51 PM
racermom167
Jul 24, 2006 02:03 PM
hitecdan
Aug 25, 2002 08:00 PM
