MAF Noise
Old Jan 1, 2010 | 08:12 PM
rews2's Avatar
rews2
MAF Noise
This morning I did the make your own CAI conversion using the factory airbox. You pull off the factory snorkle that goes into the fender and replace it with a 3" PVC pipe and use a rubber coupler to connect the PVC to the airbox.
I went out tonight to run to the store and my truck was making this wicked whine sound that sounded like a throwout bearing going out or a whale trying to communicate with me. I popped the hood and opened the airbox and it seemed to be coming from the MAF. The noise was worse when my truck was cold and not so bad after I got home but it was still there. I also cleaned the MAF with electronic contact cleaner. Is it possible that I created too much airflow? I can't see how it would be too much flow but have to ask. I did a test run after I finished the airbox and there was no noise and it ran fine.
Any ideas or suggestions?
Old Jan 1, 2010 | 08:39 PM
madsonp's Avatar
madsonp
I'd say you changed the air flow in such a way it's causing a whistling type affect.
Old Jan 1, 2010 | 10:03 PM
rews2's Avatar
rews2
It sounds more like a whine or hum than a whistle or air leak.
I also cleaned the IAC with throttle body cleaner. I searched some other posts and I guess I should have used the same electronic cleaner I used on the MAF. I just cleaned the IAC again with the cleaner I used on the MAF and the hum is slightly there. I unpluged the lead on the IAC and the hum stops so at least now I know what the problem seems to be.
I'll run it around tomorrow AM and see what happens.
nebechanezer
Feb 12, 2013 07:37 PM
flareside_thunder
58
Sep 17, 2007 04:39 PM
matt16289
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 13, 2006 03:58 PM
plugugly
15
Jan 3, 2003 09:14 AM
Rockwell
May 16, 2002 03:13 PM
