help with vin decode.
Old Jan 1, 2010 | 11:08 AM
c.l.nye's Avatar
c.l.nye
Help, I need to find out what options this truck has/had. thanks in advance.
F14SNBF2527
I know it is a 400ci auto 4x4.Wondering about options ect.
here is a pi of the door tag.
Old Jan 1, 2010 | 12:54 PM
starmilt's Avatar
starmilt
At the top of page there is a vin decoder under articles and specs.
Old Jan 1, 2010 | 02:28 PM
c.l.nye's Avatar
c.l.nye
I tried that and it told me I have a 78 4x4 with a 400 4Barrel and that was it.
Old Jan 1, 2010 | 02:34 PM
freakboy's Avatar
freakboy
If you get the rest of the numbers that is on your tag im sure numberdummy will come around and decode all of that for you....
Old Jan 1, 2010 | 02:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That's about all you can tell from the VIN. If you want to know what options and equipment came with your truck from the factory you will have to either contact Ford customer service (free) or Marti Auto to research your VIN. Marti Auto Works - Concourse Quality, Hobbyist Price
Old Jan 1, 2010 | 06:52 PM
c.l.nye's Avatar
c.l.nye
what would a axle code H2A BE? trans code G is a c6.
Old Jan 1, 2010 | 07:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
H2= 3.50 limited slip,3.6M capacity, Ford 9". For "A" the parts book isn't clear. This is the front axle, the book shows for '74 this is a DSO special order 3.8M capacity axle then the book jumps to 78-up saying "A" signifies adjustable steering column with power steering but doesn't show "A" for '77
Old Jan 1, 2010 | 08:14 PM
76f350spercamprspeal's Avatar
Bill (aka "The Big Dummy") should be along shortly....
Until then, Can I try?
If it's wrong, I'm sorry, I tried...
F14 = F-150 4 Wheel Drive
S = V8 - 400ci - 2-Barrel Carburetor
And...
That's all I can decode my friend, The only other thing the VIN gives you that I haven't is the Transmission and the consecutive build number.
Post up the Warranty Plate Info, Located on the driver side door below the latch thingy.
Old Jan 1, 2010 | 09:32 PM
c.l.nye's Avatar
c.l.nye
thanks mike, I am trying to decipher the door tag and this helps.
Old Jan 1, 2010 | 10:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I didn't catch the 1978 in your VIN decode. I was thinking you had a '77. The "A" signifies adjustable steering column with power steering.
Also, "S" is a 400 2bbl., I don't believe Ford ever produced a 4bbl. version.
"N" signifies the Norfolk, Va. assy. plant.
If you post the entire door tag we can probably decode the whole thing for you.
Old Jan 2, 2010 | 06:04 PM
c.l.nye's Avatar
c.l.nye
door tag pic added
