Connecticut Chapter Join Chapter, Leader:
January B/S thread
Old Jan 18, 2010 | 08:59 PM
  #451
7.3 Rocket's Avatar
7.3 Rocket
Andy any day of the week works for me. I've got no life to schedule around.
Old Jan 18, 2010 | 09:03 PM
  #452
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Jim:
The RPMs for 65 MPH will be 2247.1
That's with the new 5.13 differential and in 6th OD at .71.
In 5th OD @ 1 then its 3164.9 RPM.
4Lo.com :: Final Gear Ratio, Crawl Ratio, Tire Size Calculators
Hopefully I'll have so much torque for my usually so lightly loaded that I'm always in 6th. OD even on the hills.
Next component once I payoff this mod is to install an OD auxiliary transmission.
Old Jan 18, 2010 | 09:32 PM
  #453
Aerocell4x4
Originally Posted by donjamer
Those look like nice tires..
Did you buy those for the load rating??
I see they are pretty high for the load per tire, but The max speed of 75 mph would get me worried..
Don:
Load rating, I went for over-kill.
I could have gone for the Nitto Tires as they would have provided sufficient load rating for my needs (when I over load the van) but they also have too much contact patch for my liking as in when the roads are snow covered.
I went with the Michelin's for the strength of the side walls, because that's where my tires have been failing, and as a plus they have a smaller contact patch than the Nitto's.
Note that the rims are only rated to 5000 pounds, so the rated load of the Michelin's is somewhat superfluous at this point.
When under inflated to the minimum listed pressure of 75 psig. the tire can carry 4390 pounds which more than meets my needs
When fully inflated to 120 psig. the tire can carry 6395 pounds, but the rim will fail.
I wonder when the Dana 70 axle fails
As for the 75 mph speed rating, I've only done that out West where the highways have such postings, and maybe West Virginia on I-70 (its posted 75, or is it 70, I can't remember now) otherwise I don't see it being an issue for me here in the East?
Another thought on the 75 mph speed rating.
Certainly that applies to a fully inflated tire at rated loading.
As I'll be running at the minimum recommended under-inflation pressure of 75 psig., and loaded well below the 4390 pounds per tire even then, I suspect that the lightly loaded tire casing will not be over-flexing (over heating).
Now as for rotational forces throwing the tire apart, I'm not so sure, but certainly I won't have the full pressure acting upon the tire belts trying to burst the 'flywheel.'
Old Jan 18, 2010 | 09:38 PM
  #454
Aerocell4x4
Good everyone.
Old Jan 18, 2010 | 09:55 PM
  #455
12engine's Avatar
12engine
hi CT, goodnight Dave.
Old Jan 18, 2010 | 09:57 PM
  #456
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Good Night Dave
Old Jan 19, 2010 | 04:34 AM
  #457
Nice Work Truck's Avatar
Nice Work Truck
Good morning guys
Looks like a rotten day today.
Old Jan 19, 2010 | 04:47 AM
  #458
IrnRngr's Avatar
IrnRngr
Good morning,...
Old Jan 19, 2010 | 05:04 AM
  #459
Zookie400's Avatar
Zookie400
rotten indeed andy! and its only tuesday?
ill try to get some pictures up today, my brother did some bright orange powdercoat with orange pearl and orange bass boat flake on a quad frame. im not sure how it came out.
have a good day everybody!
Old Jan 19, 2010 | 05:07 AM
  #460
Zookie400's Avatar
Zookie400
this picture doesnt show much, but its a teaser i guess....
http://hphotos-snc3.fbcdn.net/hs132...._1151893_n.jpg
Old Jan 19, 2010 | 05:43 AM
  #461
sddesigns's Avatar
sddesigns
FTE Emeritus
Good Morning CT.......
Old Jan 19, 2010 | 06:56 AM
  #462
gbroehl1's Avatar
gbroehl1
Good morning everyone!
Old Jan 19, 2010 | 07:02 AM
  #463
sddesigns's Avatar
sddesigns
FTE Emeritus
morning Greg!
  #464
BIGKEN's Avatar
BIGKEN
Good morning CT!!!
Old Jan 19, 2010 | 07:13 AM
  #465
gbroehl1's Avatar
gbroehl1
Good morning Steve! Still planning on coming up Saturday?
