460 EFI head question
Old Dec 31, 2009 | 02:51 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
So I know that there are two different EFI heads that the fords used on the 460s, and I know that the later one flowed better... but how much better are they and what year did they start using these heads? Reason being I found a good deal on a fresh rebuilt 88 460 and was wondering if I really need to swap the heads on it. It has a vortech supercharger already on it and I plan on doing a MAF conversion and a more agressive cam so should I swap the heads?
Old Dec 31, 2009 | 08:04 PM
House Husband's Avatar
House Husband
88-93 E7TE. 94-97 F3TE.....Can't tell exactly how much better the F3TE is, but in class A motorhome service, they picked up 15HP. Also run cleaner allowing Ford to eliminate the catalytic converter.
Richard
Old Jan 1, 2010 | 06:46 PM
bduff007's Avatar
bduff007
The valves are bigger in the F3TE heads. The runners may be a better too, though not sure on that.
Old Jan 2, 2010 | 07:05 PM
monstertrucker's Avatar
monstertrucker
I know on a 1989 460, the exhaust ports are slightly larger than the ports on my 1990 460 heads. I need to see what castings mine are.
Rich
Old Jan 3, 2010 | 06:50 PM
OldRacerGuy's Avatar
OldRacerGuy
I think pressurized induction would make the slightly lower flow of the E7TEs irrelevant. I'd run the 88 heads unless you find a set of F3TEs for not much more than free.
mike83f250
Feb 19, 2010 10:53 AM
bob1987f
Dec 14, 2009 07:11 AM
horsediente
Engine Swaps
Apr 23, 2009 02:14 PM
dutchlincoln79
17
Mar 16, 2008 03:47 PM
kellar
Sep 12, 2007 01:15 AM
