Alternator Swap 2003 Excursion 7.3
Old Dec 31, 2009 | 11:31 AM
bulletpruf's Avatar
bulletpruf
Ok, I'm a spaz. Had the meter on the wrong setting. Tested again with and without load and everything looks fine.
Thanks!
Scott
Old Dec 31, 2009 | 11:47 AM
SpringerPop's Avatar
SpringerPop
Yes, AC volts will give you a very different reading from DC.
On "AC", you will only read the unfiltered (by the battery capacity) "ripple" from the diode pack.
It's insignificant unless you hear it in sensitive communications equipment. Then it's just "annoying"!
How many miles on your rig? I'm trying to keep a mental average of alternator life. So far, it's (very) roughly 140,000 miles or so before the brushes wear out, which is virtually the only failure mode for those with stock power demands.
Pop
Old Dec 31, 2009 | 12:42 PM
LS1_SE7EN's Avatar
LS1_SE7EN
Glad I'm not the only one that thinks that hose is in the wrong place.
Old Dec 31, 2009 | 01:35 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by maevans
ROBIN..... You always have to out do me !!!!!!! J/K
Thanks for another pic I can steal and use in the future. and HAPPY NEW YEAR Bud.
You know me Mark. I'm a picture posting fool.
Happy New Year
Originally Posted by F350-6
Thanks Robin. I guess it is the driver side you pull toward. I must have been thinking of which way the bar leaned after the belt was removed.
It was fresh in my mind. Just removed the belt for inspection. I pushed then I pulled. I had a 50-50 chance and got it wrong the first time.
Happy New Year
Old Dec 31, 2009 | 04:55 PM
bulletpruf's Avatar
bulletpruf
Pop
Pop -
Truck has 103k. 2003 Excursion.
Thanks,
Scott
LipschitzWrath
22
Aug 14, 2017 05:22 AM
greg_8507
Jan 20, 2014 03:43 PM
90pioneer
Jun 4, 2011 09:51 PM
Juche
1983 - 2012 Ranger & B-Series
Feb 20, 2011 10:24 AM
sigtauenus
Electrical Systems/Wiring
May 22, 2007 01:17 PM
