P0381,GLOW PLUG MAL. P0197,P1212? NEED HELP.
I've just got done rebuilding my 7.3 and was running pretty good, accept for starting in cold weather.
I have codes P0381 glow plug cir malf, P0197 EOT cir low input,P1212 IPC volt low input, and P1211 injector pressure above below desired?
I have repaced the IPC, EOT, and glow plug controller erased the codes
and they still come on dosent start unless pluged in so I dont think the glow plugs are working. As for the injector code I have no idea what that could be, I have new injectors and o -rings??
Any ideas would help thanks.
Yes. The GPR has 2 large posts on it. One will have battery voltage (12v) with the key turned off. The other large post will only have power for up to 120 seconds immediately after the key is turned on. If you don't see power at the 2nd large post then you either have a bad relay or a wiring issue.
To test the glow plugs you need an ohm meter. Disconnect the flat wiring connector on the inboard side of each valve cover. You will see 9 flat pins inside there. Test the front two pins and rear two pins on each side against battery ground. An ohm reading of less than 2 ohms indicates a good glow plug.
tidexp
23
09-09-2012 08:37 PM
