P0461 code what does it mean?
Old Dec 29, 2009 | 06:16 PM
broncobilly66's Avatar
broncobilly66
My CEL came on today. I had the code read, came back P0461- fuel level sending unit condition... '06 f150 screw fx4 36,000 miles , if it matters.
Several months ago the gas gauge was slow to rise after I filled the tank,only happened once, I read on FTE to put in injector cleaner. I did everything was great.. till now.. Is this related? Anybody had this code? I don't wanna pull the tank. the pump is fine , as far as I know the gauge is working Input please
Old Dec 29, 2009 | 06:21 PM
bridge's Avatar
bridge
Sick 'n Tired
Fuel level sensor A circuit range/performance.
Possible causes: Fuel level circuit intermittent, signal line open circuit.
Also lists electromagnetic interference from aftermarket devices as a possible cause. Do you have HID lights?
Old Dec 29, 2009 | 06:32 PM
broncobilly66
No, all stock. Except for plug and play satilite radio reciver. Any Ideas??
Old Dec 29, 2009 | 06:39 PM
bridge's Avatar
bridge
Sick 'n Tired
The description of the code just states "Excessive electrical noise". Best guess is you've got a loose or bad connection somewhere.
Old Dec 29, 2009 | 06:48 PM
broncobilly66
I wonder if this was a fluke thing and i can unhook the battery and it will go away? I hate working on the daily driver Thanks for all your help. I can't be the only guy with one of these trucks with this code, Ya'll chime in ..Please, Thanks again
Old Dec 29, 2009 | 07:14 PM
broncobilly66
Well I dunno.. I just disconnected the batt. cleared the CEL. the gauge went from showing about3/4 to just under 1/2.. Which should be about right i guess(200 or so miles on tank) Maybe I need some more injector cleaner seemes my gauge had a brain fart. I hope it stays off. I can't stand a light on in the dash.. Any input??
Old Dec 29, 2009 | 07:39 PM
bridge's Avatar
bridge
Sick 'n Tired
Some quick research turns up the following possible causes as well:
Bad gas cap
Bad gas with high sulphur content
Solution is to replace the cap and find a new fuel station. Also run some fuel conditioner through the tank. The post I read suggested Red Line Fuel Conditioner.
Marlin4622
Sep 11, 2017 09:03 AM
FTreeFidd
Jul 10, 2017 12:11 AM
i eat hybrids
May 20, 2017 10:15 PM
BTFordGuy302
32
Jan 22, 2017 06:23 PM
bronkntrukholik
Jan 20, 2013 06:29 AM
