oil pressure
Old Feb 24, 2000 | 08:19 PM
77_F150_4x4's Avatar
77_F150_4x4
oil pressure
my 77 F150 has been making me worried i am going to be tearing it down and rebuilding it soon. But after about 5mins of running the oil pressure will drop to 5pounds at a idle and 25-30 running it at 5mph or 55 . should i be worried? the motor is a 351M with 78thousand scence 88 when it was restored for is firest time.
thanks
Curtis
Old Feb 24, 2000 | 08:59 PM
jowilker's Avatar
jowilker
oil pressure
Curtis keep right on driving that truck with confidence.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Feb 25, 2000 | 09:42 AM
390fe's Avatar
390fe
oil pressure
My '70 390 has the same low oil pressure symptoms as your engine. I'm going to put a new oil pump and new bearings in it as soon as I get my engine stand back. When my truck is at operating temp, I can only go about 45 mph. Things are rattling above that speed. Untill it's warmed up, I can do 90 mph without any rattling.
Old Mar 7, 2000 | 11:48 PM
Superdave's Avatar
Superdave
oil pressure
Old Mar 11, 2000 | 02:47 PM
BJs77F150's Avatar
BJs77F150
oil pressure
I had just installed a rebuilt 400m, at 1500 miles on rebuild the oil pressure started doint the same thing. By 2000 miles there was a distinctive knock from the lower part of engine. Pulled it back out and found that 3 rod bearings were already going bad(possibly due to overtorquing them). So I was back to square one and just went ahead and rebuilt it from the block up, and did it right this time.
The oil pressure is doing fine now at about 55 to 65 psig after warm up and running 55 mph. If it isnt makin a racket......... drive on until it tells you "It's Time". Good luck.
77 F150 4x4 400M C6
99 Durango 360 Magnum
Old Mar 11, 2000 | 03:16 PM
deleontow's Avatar
deleontow
oil pressure
If the truck is not knocking I would not be too worried. The cause is too much clearence between the crank bearing and the crank. In other words the bearings are slightly worn, causing the loss of oil presure on idle. You can keep driving like or you can replace the bearings while the engine is still in. If you hear any kind of knocking than the bearings are too worn and need to be replaced before any more damage occures
Dave
http://members.aol.com/deleontow/auto/index.htm
Old Mar 11, 2000 | 07:46 PM
77_F150_4x4
oil pressure
no there is no knock the only knock it has is from the bad right side exhaust gasket.
Curtis
77_F150_4x4
Oil & Lubrication
Jul 5, 2006 11:01 AM
77_F150_4x4
Mar 20, 2001 08:06 PM
77_F150_4x4
Sep 25, 2000 03:47 PM
77_F150_4x4
Aug 7, 2000 11:06 AM
77_F150_4x4
Mar 28, 2000 08:32 PM
