Hard to start!!!!!!!
Old Mar 12, 2000 | 12:53 PM
BJs77F150's Avatar
BJs77F150
I am pretty new to this list, and you guys seem to have alot of knowledge on these sweet ole trucks. I have my 77 F150 with a fresh rebuilt 400m, with 4 barrel and headers, about 100 miles on engine. My problem is that doesnt want to fire off in the morning. It cranks freely but doesnt seem to want to fire. I live in Alaska and it is 18 degrees here this morning, I plug in my block heater just to keep it warm. When it does finally fire off it runs fine and I can start it for the rest of the day with just a touch of the key. But it has been doing this for the last three days. Did I miss something?
BJ 1977 Ford F150 4x4
1999 Durango 4x4
Old Mar 12, 2000 | 01:55 PM
camotruck's Avatar
camotruck
what kind of igntion are you using?
Old Mar 12, 2000 | 02:36 PM
BJs77F150's Avatar
BJs77F150
Camotruck:
I am using the stock ignition system. Just put new performance plug wires on it, but other than that it is all Fomoco...
Old Mar 12, 2000 | 07:25 PM
sparky's Avatar
sparky
It is possible that the fuel is draining out of the carb overnight? That way the engine wont start until the carb is refilled by the fuel pump. Before you start it tommorrow, for the first time, look into the carb and pump the throttle linkage by hand. If you see fuel squirt in then my guess is wrong. However if you dont see fuel squirt in then this could be the prob.
Just a thought.
Sparky
Old Mar 12, 2000 | 07:48 PM
BJs77F150's Avatar
BJs77F150
Thanks for the input Sparky. I have been tossing that thought around all day. Waiting till the AM to give it a try. I just bought that 600cfm 4 barrel Edelbrock about 5 months ago and had it on the engine before rebuilding it last week. But I keep coming back to it myself. Thanks again...
Old Mar 13, 2000 | 02:57 PM
BJs77F150's Avatar
BJs77F150
Well I checked the carb this morning before trying to start my truck. It had fuel spraying out from the first push of the throttle cable, so the fuel leaking out isnt the problem. It started a little easier this morning, but still had to crank it for a couple of minutes. I am contemplating a hotter (newer) coil for this situation. Any thoughts. I am open to inout.... I have used Mallory and Accel coils in the past. Anything better out there?
Old Mar 13, 2000 | 10:14 PM
jbhf250's Avatar
jbhf250
Just for luck... Try a larger plug gap to see if it responds better on the cold start....and yes I`de put in a fresh coil..
__JOHN__Õ¿ö
72 F-250
http://clubs.excite.com/comm/area/pw/welcome/main.asp?cid=188005&auth=
Old Mar 13, 2000 | 10:32 PM
BJs77F150's Avatar
BJs77F150
I put a MSD Blaster 2 on today and will give it a try first thing in the AM, It seems to be starting easier as I get a few miles on the rebuild. I followed that tech article from this site and used the flat top pistons and mild cam, Had the block taken .030 and took .010 off the heads. I think it may just be a little tight during the break in. Thank you all for your input. This is my first Ford redo since the late 60's, Feel like a kid again. But glad my pockets are alot deeper now. LOL...
BJ 77 F150 4x4
99 Durango 4x4
Old Mar 14, 2000 | 01:02 PM
BJs77F150's Avatar
BJs77F150
The new coil seems to have done the trick. Thank all of you who took the time to reply to my problem. :-) Now All I have to do is wait for all the ice to melt in my driveway so I can continue on with the restoration.
Old Mar 14, 2000 | 03:54 PM
SEANSTER's Avatar
SEANSTER
I have a 77 F150 with the 400, i found that hard starting was in the choke settings, those edelbrocks come out of the box set pretty lean, have you tried the idle mixture?? are the plugs white?? im new to this site so if any one wants to help me with my F150 eme seanwb@tisd.net
SEANSTER 77' F-150 400 Edelbrock performer package (the worx)
Old Mar 14, 2000 | 07:00 PM
78_F1HUNDO's Avatar
78_F1HUNDO
alaskawoobie
New Member Introductions
May 9, 2013 10:27 PM
Alaska Josh
May 1, 2013 07:32 PM
arkoch
Feb 7, 2010 07:37 PM
Alaska Tom
1983 - 2012 Ranger & B-Series
Sep 26, 2008 10:28 PM
Frosty Ford _Alaska
User Gallery & Picture Display
Mar 13, 2002 10:32 PM
