>And also, all i replaced was
>the points. I can still
>use a cap for electronic
>ignition?? What about my rotor,
>will i need to get
>that from a later model
>too?? Sorry about all the
>questions but Im new to
>the ignition game.
Do NOT use the capacitor with the Pertronix module!!!
If you use the large cap setup you will have to use a matching rotor...
> What is the capacitor??? Where
>do i run the wire
>from that goes to the
>positive side of the coil??
>Di i leave the old
>wire hooked up also??
1. the capicator was part of the old points setup.. the small `Can` looking like thing held in by 1 screm .it had a wire that connected to the points
2.run it from the ignition switch to the +..plus..side of the coil
3. no... If you are getting LESS THAN 11-12 volts from it. Thats what the New one is for.
IF you ever go back to points ignition it will be there waiteing to serve again
