Ok just Finnished head job. Truck runs great just long crank to start (6 sec). Put the ae on it and came up with this code for cylinder 8 glow plug circuit. Do you think it's the harness or controler. it is an old controller (not the one that was on the truck when started head job). Or what eles could it be. They are brand new glow plugs. I put them in on the head job.
new does not always equal good. ohm out the buss bar from the 4 pin to ground. each pin should be 2 ohms or less. if thats good suspect controller.
Yep you were right on #8 plug failed test replaced it and now runs great. I even tell pepole all the time that new isn't always good. Guess should have taken my own advise thanks again
[quote=3000 FPS;8295516]Oh I totally agree. The dielectric grease does help keep moisture out and it helps prevent arching in high voltages like spark plugs and wires.[/quote
Thanks for the clarifications 3000 FPS - it is always good to make sure the correct information is provided!
