Rag joint replacement?
Old Dec 12, 2009 | 04:44 PM
78150custom's Avatar
78150custom
I was told the loose steering in my '78 f150 2wd was causing by the original rag joint. So I found this Borgeson Rubber ''Rag Joint'' Steering Couplers - JEGS. It would the first one on the list. Then I did more reading and found out I could replace the rag joint setup entirely with a better, stronger u-joint setup? I know it would cost more, but it would last longer from what I know. What all would be required besides the ujoint? a new steering shaft as well?
Old Dec 12, 2009 | 07:08 PM
giftshopduane's Avatar
giftshopduane
Thats a bit much for a rag joint, I think LMC or ebay they are like $40-70, somewhere around there. I would just go to your local parts store, there is a company that sells parts labeled "help" I don't know who they are, but it seems like everyone carries it.. get the universal rag joint repair kit, or ask for it. I think there are a couple versions, get the one that fits your truck, and use it. I just got one for $8 here. Its relatively easy to fix, since your truck is an F150 2wd, your most likely not running big tires and abusing the truck, putting a lot of stress on the steering components, this fix should give you years of service.
Old Dec 12, 2009 | 07:20 PM
BSCowboy's Avatar
BSCowboy
giftshopduane is right, I used the help section of my local parts store to replace mine.
shorerider16
18
Jul 22, 2016 06:48 PM
tl1965
Nov 26, 2015 07:15 PM
ShortBed'86
Jun 25, 2012 04:26 PM
ag30265
Feb 9, 2009 04:40 AM
30over
Aug 22, 2004 10:52 PM
