Horn Button Spring
Old Dec 27, 2009 | 02:44 PM
xstrange's Avatar
xstrange
Horn Button Spring
A question for Bill (NumberDummy) or anyone else:
I need a horn button spring for my '67 F100. It's the large steel spring that goes right under the button and/or ring. Is that part the same on just '67-'72 trucks, or does it go beyond that?
Is it still available from the dealers? I'm in Burbank, 91502, so Galpin Ford is my usual parts place.
Thanks!
Old Dec 27, 2009 | 06:25 PM
orich's Avatar
orich
71 & up f100 -350 used a 2 spoke S/Wheel with a horn touch pad...
I'm pretty sure the early vans will work on yours also..
orich
Old Dec 28, 2009 | 12:28 AM
GreenDinosaur's Avatar
GreenDinosaur
If it's got a 3 spoke steering wheel, you should be able to get it from LMC
Old Dec 28, 2009 | 09:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by xstrange
I need a horn button spring for my '67 F100. It's the large steel spring that goes right under the button, not the ring.
Is it still available from the dealers? I'm in Burbank, 91502, so Galpin Ford is my usual parts place.Thanks!
FY1: The horn button spring is not the same as the horn ring spring (CODZ13A807B).
CODF13A807B .. Horn Button Spring / Obsolete
Galpin doesn't have any.
PARTS INTERNATIONAL in Farmers Branch TX has THREE = 888-727-0418.
JST AUTOMOTIVE in Lebanon TN has THREE = 615-443-3086.
GREEN SALES CO. in Cincinnati OH has FIVE = 800-543-4959.
Fits: 1961/65 F100/250 2WD / 1966 F100 4WD / 1966 F250 2WD / 1967/70 F100/350 2WD/4WD / 1968/82 F500/750 / 1970/82 C Series Tilt Cabs / 1970/85 L/LN500/900.
Fits: 1960/64 Falcon/Comet / 1962/64 Fairlane / 1966/70 Falcon / 1966/73 Bronco.
orich: Pretty sure doesn't cut it. You are either sure...or not. In this case, it's...or not.
The 1961/67 Econoline horn button's do not use this same spring.
The spring used on 1961/67 Econoline horn button's is C1TZ13A807B which also fits 1961/65 F100/250 4WD / 1966 F250 4WD / 1969/74 Econoline.
Old Dec 28, 2009 | 10:15 AM
orich's Avatar
orich
Well, I stand corrected by the one and only guy who would know for sure..
orich
Old Dec 28, 2009 | 03:23 PM
xstrange's Avatar
xstrange
Thanks, Bill! That's what I needed to know.
Could you also post the availability for the spring for the horn ring (CODZ13A807B)? If any of the same places have both, that'll make it easier to order them.
It makes sense that they would be different parts. The ring spring is probably much stiffer than the button spring.
When I bought my F100, everything was missing in the center of the wheel. Fortunately, the little contact button didn't fall out, and the horn works if you electrically short the button to ground.
On ebay, I managed to find an original horn ring in pretty good shape, but it's missing the center emblem and the plastic retainer ring. Then I found a NOS horn button assembly, which has the emblem and retainer. Since I have the parts to go with either the ring or the button, I may just buy both springs to give me the option. I'll probably go with the ring for class, but I may turn out to like the button better.
Thanks again for your help!
Bruce Johnson
Old Dec 29, 2009 | 04:05 AM
NumberDummy
C3DZ13A805B .. Horn Ring / Obsolete / REPRODUCED
When Ford sold the ring, it came assembled with everything (except the spring). The repops come Sally Rand, everything else is required.
Fits: 1961/65 F100/250 2WD / 1966 F100 4WD / 1966 F250 2WD / 1967/70 F100/350 2WD/4WD / 1960/63 Falcon/Comet except 1963 Falcon Sprint.
In the late 1960's, Ford painted the horn ring argent to reduce glare. It cuts down on the glare all right, but looks FUGLY. Underneath the paint, it is NOT chromed.
When Ford did this, they did NOT change the part number, which means: Be careful what you buy...that NOS horn ring could be chrome, or maybe not.
CODZ13A807B .. Horn Ring Spring / Obsolete
Fits: 1961/65 F100/250 2WD / 1966 F100 4WD / 1966 F250 2WD / 1967/72 F100/350 2WD/4WD / 1960/69 Falcon / 1962/69 Fairlane & 1968/69 Torino/Montego except wood grained wheel.
Fits: 1963/64 Galaxie / 1965/69 Galaxie/LTD/MUSTANG except wood grained wheel / 1966/73 Bronco.
Give Bo a call at Mustang Service Center in North Hollywood (818-765-9266), he prolly has some.
REDLANDS FORD in Redlands CA has 1 = 909-793-3211.
CLEVENGER FORD in Porterville CA has 15 = 800-570-5554.
JST AUTOMOTIVE in Lebanon TN has 17 = 615-443-3086.
WESLEY OBSOLETE PARTS in Liberty KY has 34 = 606-787-5293.
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 204 = 800-543-4959.
Old Dec 30, 2009 | 12:36 AM
xstrange's Avatar
xstrange
Thanks again, Bill!
I called Bo at Mustang Service Center and they have a few of the ring springs, so I'm going to stop in there tomorrow. I'd driven by the place but have never checked them out.
The horn ring that I got from ebay is plated, although it's a satin-ish finish. It doesn't look like it's been scrubbed or anything, but it's not bright chrome. It has some pitting but is decent looking overall. It'll be fine for this truck for now. Its cast-in part number is C8TA13A800-F. I realize that's the part number for just the ring, not the ring assembly as was stocked. The ebay seller claimed it was from a '67 or '68 F100.
Old Dec 30, 2009 | 08:49 AM
NumberDummy
Thanks again, Bill!
Its cast-in ID engineering number is C8TA13A800-F. I realize that's the ID number for just the ring, not the ring assembly as was stocked.
The ebay seller claimed it was from a '67 (it's not) or '68/70 F100/350.
There are no actual Ford part numbers on any parts after 1956, just ID numbers (when applicable).
When you stop by Mustang Service Center, ask Bo if he knows the difference between a bar of soap and a valve seal.
I've been ragging on Bo since he said something to this effect back in 1975.
Old Dec 30, 2009 | 05:43 PM
xstrange's Avatar
xstrange
I stopped in Mustang Service and got the horn ring spring from Bo. That place is an amazing resource if you're into old Mustangs and Falcons. He has some small truck parts, but not much.
I asked him about the soap and valve seals....he laughed and shook his head and said I didn't want to know. He told me some stories about your involvement in the big auctions when he acquired much of his inventory. A real nice guy.
rzns60
Sep 12, 2020 12:02 PM
FordPickup460
Nov 30, 2019 12:23 PM
centralNH
Mar 17, 2014 08:51 PM
sleddog60
May 18, 2009 09:29 PM
Metdawg44
Mar 20, 2008 11:46 AM
